94Civic EG B20B Intermittant gear selection problem
Old Feb 19, 2014 | 01:04 PM
zakl's Avatar
Default 94Civic EG B20B Intermittant gear selection problem
94Civic EG B20B
Hi there, The issue I am experiencing is I cant select gears randomly this happens. What I have noticed is that I can select gears fine when I just start the car and seems to have an issue when after I drive and select the reverse gear then it doesnt go into reverse gear and grinds and no gear will select but lets say I drive the car and dont select reverse gear it will select fine. So the issue seems to be triggered only after selecting reverse gear (also it seems when the car is cold or not driven for long periods reverse will go without any issue)
I have changed the clutch, pressure plate and release bearing about a month back with a Valeo
your kind advice will be appreciated thx
Old Feb 19, 2014 | 01:05 PM
Former User's Avatar
Default Re: Intermittant gear selection problem
What transmission? Is the transmission fluid fresh? What transmission fluid do you use?
How does the clutch pedal feel? Spongy or loose? Any fluid leaks, such as above the clutch pedal?
Old Feb 20, 2014 | 09:17 AM
zakl's Avatar
Default Re: 94Civic EG B20B Intermittant gear selection problem
Hi, it.has a dseries s20 transmission. The transmission fluid was replaced about a month ago with a new clutch. Its manual fluid not sure of the name it was the 1st time Ibought it. The clutch pedal has good resistance feels the same as when it worked fine. Thr is a slight leak from the gearbox seal but it is very little though
Old Feb 20, 2014 | 11:16 AM
tony_2018's Avatar
Fish Twig
How the hell............. a d-series tranny on a b-series motor?
Old Feb 20, 2014 | 12:41 PM
carlos8's Avatar
Are you sure is a s20 Trans. and if is matted to a b20 post a pic!!
Old Feb 20, 2014 | 01:48 PM
slowDB7's Avatar
Would like to know how to?
Sure its not a s80
Ricextacy
Transmission & Drivetrain
13
Mar 17, 2009 07:57 AM
chocolatesk8er10
Jul 25, 2007 11:24 AM
integracura
Apr 18, 2007 11:18 AM
Leo C
Jan 21, 2007 09:07 AM
Leo C
Jun 26, 2006 02:22 PM
