Prepping car for move
Old Feb 18, 2014 | 12:47 PM
Jmb106jr's Avatar
Default Prepping car for move
My Daughter is graduating from collage in May and will be moving from Fl to Huston Texas for 2 years. It is are 95 Accord Ex 2.2 w/ 134k. We bought it 14 months ago, other than routine Maintenance, air filter, plugs, oil changes and Drain & fills of the ATF and a new Radiator the car has been perfect. Now i don't have any service history previous to me buying it but from what i can see the car was serviced at a Honda Dealer it had a genuine Honda Oil filter on it, a Honda Air filter, the plug wires were replaced w/ genuine Honda wires circa 2008. Now i plan to Change the Timing Belt/Water Pump,Coolant, Cap, Rotor,Plugs, Air Filter, Belts,Hoses,Front & Rear Brake Pads,Brake Hydraulic Hoses & Brake Fluid. Clean Throttle Body, EGR Valve & passages. It has brand new tires just put on 3 months ago. Is there anything I have forgot that should be replaced as to make the car as reliable as possible?
Thank You.
Joe
Replace the Sears DieHard Battery, Oh and forgot about the T-Stat replacement.
Old Feb 18, 2014 | 12:54 PM
cptbarkey's Avatar
Default Re: Prepping car for move
your plan is pretty comprehensive. the EGR valves probably could use some preventative cleaning, and inspect all the coolant hoses for dryness or cracking. inspect the suspension for creaks also. ericthecarguy has an excellent youtube channel which instructs you on how to diagnose all of these issues.
Old Feb 18, 2014 | 04:32 PM
MAD_MIKE's Avatar
MM Gruppe B
With 100K miles on the clock, I would look into replacing the front wheel bearings, and the lower ball joints. This will maintain nice even tire wear on the front and reduce any chances your daughter may get hosed with a stupid price for a replacement if they start howling while she's away. Axles are easy enough to change, but I would do that while you have the front end apart.
Old Feb 18, 2014 | 04:56 PM
Jmb106jr's Avatar
I never thought about those. Thanks Mike
vietkangta
Jul 28, 2007 12:43 AM
skiptomylou
Mar 22, 2006 04:46 PM
djtech
40
Jul 10, 2003 10:16 AM
djtech
Jan 29, 2003 07:02 PM
djtech
Jan 29, 2003 06:51 PM
