rebuilding engine?
Old Oct 29, 2002 | 12:15 AM
iwouldHITit's Avatar
Default rebuilding engine?
dont know much about engines but im planning to rebuild my d15 and turbo it in the future..what are some things i sould change? should i use oem parts or aftermarket?and how much do i expect to spend to rebuild...thanks
Old Oct 29, 2002 | 12:42 AM
Kamin's Avatar
Default Re: rebuilding engine? (iwouldHITit)
1) buy a helms. http://www.helminc.com
2) pay attention. not to be mean, but you dont sound like your ready to build a motor.
Old Oct 29, 2002 | 07:31 AM
civicsitek GanGsTa's Avatar
Default Re: rebuilding engine? (KAMiN)
Instant message me or email me for info. Depending on your ultimate goals, the products you sue my change around a bit. Forged pistons and eagle rods would be optimal, but if cost is a factor there are other way to go about it. Drop me a line.
Old Oct 30, 2002 | 02:04 PM
Death_to_Thieves's Avatar
save your money aNd go with a b series moror. D15 motor is JUNK
Old Oct 30, 2002 | 10:01 PM
Default Re: rebuilding engine? (8000KReV)
only junk if you have no engine building and tuning skills...... why are there people running 10 second passes on single slam non vtecs if they are junk?
Old Oct 30, 2002 | 11:13 PM
lazerus's Avatar
Default Re: rebuilding engine? (civicsitek)
building your engine is nothing easy.
but i built my first engine no problem. it's all in the research. make sure you have all the proper machining done, use the correct rods and main bearings, always torque bolts lubed with motor oil/moly lube, and always pre-lube your parts, and keep everything clean!!
here's a rundown of some stuff i'd recommend:
mill the head (flat)
3-5 angle valve job new seals, inspect guides.. springs if necessary.
Proper line bore job, with a proper grit on the cyl walls depending on rings (inform your machine shop of which type of rings before they bore)
have the whole engine assembly balanced. rods, flywheel harmonic balancer/accessory pulley
have the rods rounded before installing them (make sure they're right on)
have the crank journals polished, and ground if necessary (machine shop will know)
inspect your oil pump/replace it (they do wear)
uhhhhhhhhhh. other peeps fill in, i can't think it's 1:30. lol
bhigh
Apr 24, 2011 09:22 AM
zsmith789
Oct 27, 2006 09:41 PM
laughinxxx
Aug 2, 2003 10:05 PM
1fastEK
Oct 30, 2002 11:28 AM
