burning coolant 98 acura integra need help!
Its a 98 acura integra not sure bout trim model but it is a two door and it has a non v b18c1 my car is burning water everyday on my way to work I need to put more water in radiator my hoses stay at an even temperature n there is no water/colant leaks anywhere I already changed my head gasket and problem still there today on my way to work the needle went all the way up I guess is now burning my water faster any help will be greatly apreciated.
Check the oil to make sure the coolant/water isnt mixing. Check again for any leaks. Im thinking its a bad head gasket. Did you torque the head gasket to spec when you replaced it?
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
