Suspension & Brakes Theory, alignment, spring rates....
suspension
Old Feb 10, 2014 | 08:50 AM
toykr3w's Avatar
Default suspension
What kind of coilovers would you recommend for a daily driven car?
Old Feb 10, 2014 | 05:23 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: suspension
I would recommend reading the stickies!!!
Old Feb 11, 2014 | 04:50 AM
Sccacivic1997's Avatar
Get some custom coilovers with 12kg front and 22kg rear and daily drive on that. Will be smooth as butter.
Old Feb 11, 2014 | 12:04 PM
egsleepercivic's Avatar
I agree... lol
OP check this and then come back with a better question if needed
https://honda-tech.com/forums/suspension-brakes-54/click-here-all-you-curious-about-suspension-setups-their-costs-reliability-2967499/
Old Feb 11, 2014 | 12:06 PM
90_EX_Civic's Avatar
naw man, don't miss lead him.
op needs to run some penske tripple adjustable shocks, with 24k front and rear springs from hyperco. dude would be baller, and be able to run it slammed with a smooth ride.
Old Feb 11, 2014 | 12:50 PM
M3THTICAL(EF)'s Avatar
progress cs-ii, koni yellow w/ots ground control sleeves, lowerings springs with kyb agx, idk look around dude.
Old Feb 11, 2014 | 06:21 PM
Listen to this dude, btw we give great spring rate advice XD
Old Feb 12, 2014 | 10:42 AM
ej6fade's Avatar
I'll be the bad guy. If you expect to be spoon-fed information, you are way off. Spend a few hours, or even days, or weeks, compiling research based on reviews, opinions, r&d, testing, etc. and what your ideal set up would be. Are you looking for a small drop and maintaining a smooth ride? Do you like a hard and bouncy ride? Are you looking for performance, looks, or both? Are you going to hella slam your car and make it superhellaflushilisticitakeitupthebuttdocious? What is your budget? Are you planning springs/shocks, coilover sleeves/shocks, or full coilovers? Do you care about quality or are you going the cheap route? Many of these questions must be addressed before asking for help. I spent 6 months doing research before I decided on my set up. We cannot help you if you can't help yourself. If you think I'm being a dick, expect a much worse answer from most of the forum.
Since that is out of the way, I have daily driven my set up for roughly two years or so, Koni Yellow Shocks/Ground Control coilovers with custom rates, I love it and wouldn't trade it. Handles extremely well combined with the rest of my suspension, and is still very comfortable for a daily.
240MANSX
Dec 19, 2007 09:38 PM
GetSmoked
Feb 17, 2005 03:53 PM
killaj12
Oct 3, 2004 01:50 PM
meanm3
Aug 22, 2002 09:00 PM
Integra187
Apr 9, 2002 06:32 PM
