What tool do you use to cut ecu casing
What up guy I was trying to install the usb bulkhead cable bracket that comes with the Demon RTP. But I was have trouble getting a nice clean cut on the ecu casing. What type of tool or bit do you guys use for this?
Heres a picture of the part Im talking about.
Thanks
Thanks
Pretty much the same, but I used a cutoff wheel on an air grinder instead of a saw. Not usually a great idea on aluminum but the cuts were small so it didn't have a chance to load up.
Make sure you remove the board from the ecu frame completely before cutting and clean it very well before reassembly.
I make an outline with a marker on the outside of the ECU case with the s300 board or the Demon USB conector installed, remove the board/connector and use my Dremel. Looks profesional!
I didnt have any tools to notch the case so I had to improvise and use a uni-bit on the cover, then thread the mini USB thru it and secure it on the center housing. I tucked it as best as I could after running to the glovebox for easy plug in to USB.
