b17 cable trans help!!!!
i have a cable jdm gsr transmission with a damaged speedo sensor. they are extremely hard to find and i dont know what to do at this moment. is there anything that i could do to fix this or do you know where i can find a replacement. any and all help would be greatly appreciated
thank you
thank you
If it makes you feel any better ive been driving my car with the sensor busted like that for 2 years without any issues. Makes it easier to work on tbh.
I guess you could wedge a piece of paper when you put the cable in to wedge it in place
i read that the ls doesnt fit
They dont have a clamp. They use a pin that slides through the gap where yours broke, and through the groove in the cable. I see plenty that have broken at the slot cut into them.
And im not 100% but I think they all work.
I just looked it up. The 93 gsr has the same part number for the speed sensor as a 90 ls 5 speed.
56500-PR3-010
The 90 autos have a different part number but im almost positive I ripped the sensor im using in my car out of a 90 auto, and I have a 92-93 ls 5speed in my car
56500-PR3-010
Exactly my point...use the vss that came with the car or the same type.... in other words a hydro vss will bolt up but not work in a da.... its electronic whereas the da is mechanical
i sure hope so. thanks, dick
[QUOTE=ghosthatch;49536299]note the pictures... they arent the same length. now what?
The sensor on the right is a D series cable and the one on the left is a B series Cable. I have a B series cable sensor for you. I will PM a price.
[QUOTE=Synchrotech-Transmissions;49550170]actually i pulled that straight out of my ys1 ls b series transmission
The sensor with the plastic gear on it is from an L3 88-91 Cable D series. Someone must have installed the wrong one in the B trans at some time.
meseetree
Jun 2, 2006 07:19 AM
EF Two
Oct 20, 2005 05:42 PM
