fuel reser switch??
Old Jan 23, 2014 | 03:28 PM
keslerbuilt's Avatar
Default fuel reser switch??
so i was pullin out of my driveway today and asll of a sudden it cut off. its not getting any gas and i know i have a FULL tank, so where would the fuel reset switch be on a 91 integra ls? i need to know this is my only transportation
Old Jan 23, 2014 | 04:17 PM
TheRealTegger's Avatar
Default Re: fuel reser switch??
There isn't one.
Old Jan 23, 2014 | 04:36 PM
any idea of what is would be? no fuel no spark, checked all the fuses they are all good.
Old Jan 23, 2014 | 05:09 PM
B_Swapped93's Avatar
main relay loose ground what happens when you try and turn it on tho ? does the engine at least "spin" (try and turn over).
Old Jan 23, 2014 | 05:41 PM
yea it turns over. just no fire no gas. it turns over healthy
Old Jan 23, 2014 | 05:42 PM
how did you confirm no spark and/ or gas ? the plugs are dry ? does the fuel pump prime.
Old Jan 24, 2014 | 05:33 AM
pulled a wire out put a screw driver in it put close to valve cover and doesnt spark, tested the igniter and coil. the pump doesnt prime. and i took the fuel line off going to the fuel rail from the canaster on the fire wall and turn it over amd no gas.
Old Jan 24, 2014 | 06:42 AM
fcm's Avatar
fcm
Old Fart
PGM-FI Main Relay, if fuel pump does not prime it may be the fuel injector relay is also not turning on, [to confirm, test for power at fuel injectors].
If there is no power at the fuel injectors then there will be no power on IGP1 and IGP2 at the ECU/ECM, so no fuel pump relay control or spark. 94
Efluis
Jun 27, 2019 09:42 AM
Weifast
Feb 25, 2010 05:43 PM
rtdillon
Nov 9, 2005 08:49 PM
trooper0641
21
Jul 24, 2005 01:45 AM
zacdaddy77
Apr 21, 2005 09:14 PM
