Rywire harness
Old Jan 17, 2014 | 03:50 PM
Yodi71's Avatar
Icon2 Rywire harness
I just installed new rywire harness in my 92 integra I'm getting fuel but I'm getting no spark. I never had this problem with my old harness does anyone have a clue what's my problem and how to fix it?
Old Jan 17, 2014 | 06:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: Rywire harness
What have you checked?
Did you check and see if you have 12V+ to the distributor assembly, [black/yellow] when the ign. switch is in the run AND start positions?
If not, start there.
If you do not already have a 12V test light, [NOT led type] get one. 94
Old Jan 17, 2014 | 06:49 PM
Yodi71's Avatar
And if that is the problem how I go about fixing it? can't be to replace the distributor cuz I tried that and still no spark.
Old Jan 17, 2014 | 07:46 PM
1998GsRIntegra's Avatar
Have you called Rywire yet? If you bought their product I see no reason why you can't call them and try to get some tech support. Just throwing it out there.
Old Jan 18, 2014 | 09:02 AM
fcm's Avatar
fcm
Old Fart
If there is a problem with power to the distributor, obviously the problem is before the distributor.
Have you tested for that YET? 94
Old Jan 20, 2014 | 07:11 AM
Yodi71's Avatar
yes i test it and its good ..and i swap distributors and still same thing
Old Jan 20, 2014 | 03:20 PM
fcm's Avatar
fcm
Old Fart
Is that with the ign. switch in both the run AND start positions? 94
Old Jan 24, 2014 | 12:18 PM
Yodi71's Avatar
yes
Old Jan 24, 2014 | 12:36 PM
Yodi71's Avatar
can the starter relay have anything to do with the problem?
Old Jan 24, 2014 | 12:45 PM
fcm's Avatar
fcm
Old Fart
If the engine cranks/turns over, [starter motor working] then no.
Check for power at IGP1 and IGP2 at the ECU/ECM, also with ign. switch in both the run and start positions. 94
Old Jan 24, 2014 | 12:57 PM
Yodi71's Avatar
and if eveything there is good what be the next step
scott757
Mar 21, 2013 05:30 PM
jdmkidUK
Nov 30, 2011 05:49 PM
oosykooo
May 11, 2011 07:24 AM
95turbotypeR
Dec 15, 2010 05:58 PM
vxnine
Jul 25, 2005 05:49 PM
