Hub and wheel bearing question
Old Jan 22, 2014 | 05:08 PM
$MIKE$'s Avatar
Default Hub and wheel bearing question
I'm planning on removing the hub to install the
Arp extended wheel studs,
Do I need to replace the wheel bearings when doing This?
Old Jan 22, 2014 | 06:54 PM
B_Swapped93's Avatar
Default Re: Hub and wheel bearing question
Nope: http://www.team-integra.net/forum/19...ud-repair.html
Old Jan 23, 2014 | 08:01 AM
known's Avatar
I would not do it that way.
Do it right, replace the bearing and do the studs at the same time.
Old Jan 23, 2014 | 08:07 AM
kyden's Avatar
Yes you will need new bearings.
Old Jan 23, 2014 | 12:29 PM
JDMFLUSH1's Avatar
agreed. bearings and studs at the same time
Old Jan 23, 2014 | 03:17 PM
$MIKE$'s Avatar
Ok I see the oem ones are like 100 each.
What one do you guys use oem or the koyo ones there's like. 50$ difference
Old Jan 23, 2014 | 03:31 PM
OEM ! when I did mine but I'm **** about what I put on my car lol and like ordering OEM only. koyo made the oem ones tho afaik so it's one of those "it may not matter things".
to everyone shooting down my link, I had just replaced my knuckle with one from the dealer(waste of $ lol) and I cross threaded my cheap ricer lug nut so I wasn't about to do new bearings too that's all. But I see nothing wrong with doing them while you're at it.
Old Jan 24, 2014 | 07:51 PM
1998GsRIntegra's Avatar
Koyo's are perfectly fine. SKF is another good alternative to NTN (the OEM mfg for Honda). Feel like I just linked this in another thread not long ago... http://www.ebay.com/itm/171152913681?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Also, it is possible to remove the hub and change the studs with out having to change the wheel bearings; I've done it before and it just comes down to luck. The problem you run into (and the reason most everyone says you must change the wheel bearing if you press the hub out of it) when re-using the old bearings is that 90% of the time the ball bearing carriers/cages get damaged when you remove the hub from the bearing and or when you press the hub back in. It's almost never something visible to the naked eye. To avoid a future headache it's best practice to just do the wheel bearings with the studs.
Old Jan 25, 2014 | 03:52 AM
$MIKE$'s Avatar
^ thanks for the info and rani was looking at that same listing on ebay.
Thanks all
Old Jan 25, 2014 | 09:16 AM
98silturboteg's Avatar
Replace the bearings they tend to lock up or separate when you separate the hub
Animefun
Suspension & Brakes
10
Jul 23, 2013 01:28 AM
jdmsir4dr
Suspension & Brakes
11
Apr 23, 2013 07:53 PM
Mike Lowwryyy
Suspension & Brakes
19
Jun 15, 2012 09:19 AM
G0TB00ST
Dec 19, 2008 09:45 AM
Mark
Oct 8, 2003 07:51 PM
