Horn stays on and wont stop - please help!!!
Old Jan 18, 2014 | 08:02 PM
jason_SIR's Avatar
Default Horn stays on and wont stop - please help!!!
So i just picked up a 1999 civic SIR and the prevous ouner had told me that the horn wasnt working so i thought to myself get a new horn slap it on easy fix so i brought the car home and have been doin a few small things to it and i notced that the horn wasnt pluged in so i go and plug it in and it just starts goin off and wont stop so i unpluged it agian can anyone help me with this .
Old Jan 18, 2014 | 08:26 PM
chillerice's Avatar
Default Re: Horn dosent work please help!!!
Sounds like bad (loose) wiring,jammed switch or shortage somewhere. Maybe the relay..
Does it have an alarm on it?
Old Jan 18, 2014 | 08:55 PM
jason_SIR's Avatar
[QUOTE=chillerice;49451413]Sounds like bad (loose) wiring,jammed switch or shortage somewhere. Maybe the relay..
Does it have an alarm on it?[/QUOt
no alarm wireing seams ok but havent checked the relay where might i find it?
Old Jan 18, 2014 | 09:29 PM
chillerice's Avatar
its above your ob2 connector near the fuse box... But I'm saying the wire running from the switch in the steering wheel could be loose or frayed somewhere... or the switch itself could be jammed.
It will be two relays....
Old Jan 18, 2014 | 09:37 PM
jason_SIR's Avatar
allight thanks for the help i will have to check that out
Old Jan 18, 2014 | 09:42 PM
BrianB16A2's Avatar
Yea def a short issue
Old Jan 18, 2014 | 09:46 PM
chillerice's Avatar
The mere fact of it staying honk sounds like a stuck relay, horn switch jammed or the wiring grounding somewhere and triggering the switch...
If the person installed an alarm before and cut the horn wire to hook it up. The trigger wire (gray) could be uncovered and grounding...
Old Jan 18, 2014 | 09:57 PM
chillerice's Avatar
OP also check for corrosion on the horn connectors.
Old Jan 19, 2014 | 10:44 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Horn stays on and wont stop - please help!!!
Also if you are going to check the steering wheel aspect of the horn for a sticky switch, make sure to follow the SRS airbag procedures. People have been seriously injured by accidental airbag deployment. I've heard of fire search and rescue people have even been killed when trying to save someone from wrecked cars where the air bag didn't deploy initially. Please be wary.
Old Jan 19, 2014 | 10:51 AM
B_Swapped93's Avatar
find the short, a test light will be your friend here.
Old Jan 19, 2014 | 04:38 PM
VeganEJ8's Avatar
See if you can pull the fuse for the horn until you figure it out
stevenmitchell
Aug 13, 2018 09:33 PM
ChrizXx
Audio / Security / Video
Nov 29, 2011 05:21 AM
Hmong EM1
10
Mar 13, 2011 07:55 PM
blasterman87
Nov 11, 2009 05:10 PM
smooz EK
Jun 3, 2004 03:42 PM
