Mechanical timing off ??
So I was trying to see if my mechanical timing was of so I put it to tdc hade as crew driver put into to see when it came up and mactched the crank pulley with the white mark and all then this is how the cam shaft was set up does this mean my mechanical is off?
The up mark is at the top kinda greenish it says and about the motor it's in a97 civic Ex the block is a d15b nothing after the B and the head is a d16y8 head
