Right Side Speakers won't work.
Hi, I have a 98 honda accord ex sedan 2.3 and the speakers on the whole entire right side does not work, only the left sides do. So I was wondering if you guys knew what the problem. Do you think it could be the speakers itself? Or loose wiring? Or maybe it might just be the radio? I'd appreciate the help from you guys. Thanks!
I'll assume you checked the balance/fader controls.
It's odd that speakers or wires for 2 speakers (front and back) would go out at the exact same time
Is it a factory stereo or aftermarket head unit?
Check voltage at the speakers. If you have power, the speakers are shot. If no power, the issue lies between the head unit and the wires. Next check the wires for those speakers behind the head unit. If you have voltage then the problem is in the wiring. If there is no voltage, the problem is in the radio itself.
EK Domo-Kun
Audio / Security / Video
May 13, 2009 11:50 AM
