Autozone / Duralast KNock Sensor
Old Jan 7, 2014 | 06:54 AM
egsleepercivic's Avatar
Default Autozone / Duralast KNock Sensor
I need a replacement knock sensor, has anyone used the Autozone / Duralast Knock sensors ? Input ? Any good ? Recommended or not ?
OBD1 B16a, JDM p30
Currently have an Omni Knock Sensor, went through the Helms and I am at the point where it says to replace the knock.
Link
http://www.autozone.com/autozone/par...er=268127_0_0_
Old Jan 7, 2014 | 01:28 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Autozone / Duralast KNock Sensor
Word on the street is they're not as good as OEM
Old Jan 7, 2014 | 02:00 PM
carlos8's Avatar
we use a lot of duralast sensors in our shop but basically for Domestic cars i.e. GM, FORD. And they work great in domestics in the few we've used in imports works fine but with a little more you can buy the OEM one, The only advantage is they have warranty always not be valuecraft.
But nothing beat OEM quality.
Old Jan 7, 2014 | 03:24 PM
Fishbone Fan's Avatar
I put one in about 12,000 miles ago and so far no issues.
Old Jan 7, 2014 | 03:27 PM
92lx's Avatar
I work at autozone and on my poormans build I replaced every sensor from the ones at autozone and I have not had one single issue plus you have a lifetime warranty too.
Old Jan 7, 2014 | 05:29 PM
yeah the oem one is about 135 +shipping online
the az one is 99 and has lifetime warranty and I am pretty sure i could find a coupon for az
probably gonna go with the az one
thanks for the replies
Old Jan 8, 2014 | 06:37 AM
93egSLEEPER's Avatar
On OBD1 you don't need a knock sensor. It can be tuned out of the ECU
Old Jan 8, 2014 | 08:40 AM
tony_2018's Avatar
Fish Twig
OBD1 B16a, JDM p30
Link
What have you tried so far to come to the conclusion that the knock sensor is bad?
Old Jan 8, 2014 | 02:02 PM
Yeah I know I have a chip from a popular chip maker on HT and it doesn't run as good as the JDM P30, but it does eliminate the CEL
I am at the part of the troubleshooting that says to replace with a known good knock sensor
Old Jan 13, 2014 | 06:28 AM
Just wanted to update.
Replaced the knock sensor with one from Advanced Auto Parts, found a 40 off 100 coupon.
No CEL since Thursday, it was coming on before within 10 minutes of driving
On the Omni Knock sensor that I replaced the plastic part that the harness plugs into was loose and moving in the metal part of the sensor.
Old Jan 13, 2014 | 07:49 AM
Ross 2.0's Avatar
In a Junkyard near you.
Knock sensors aren't that big of a deal.
I've been surprised at getting OEM stuff out of parts store boxes before too. Usually with CarQuest stuff though.
wantboost
Jul 10, 2013 07:53 AM
Rays99accord
Jan 9, 2012 03:04 PM
00civicsiboy
Apr 27, 2009 09:53 AM
rorik
May 27, 2008 05:48 PM
elpiar
Jul 18, 2005 07:17 PM
