zex compatibility ?'s
Old Oct 28, 2002 | 09:18 AM
hondafrk's Avatar
Default zex compatibility ?'s
I was just wondering if most zex kits are universal or model specific,
Basically, will a honda kit work correctly for a Toyota celica.
Ive done some searching on the zex website and it seems that they are model specific but other places tell me that they are universal.
The kit is not for my hatchie but for a buddies celica. I just dont want him to waste his money on the wrong kit.
I just dont know a whole lot about the compatiblity of the kits.
Old Oct 28, 2002 | 03:03 PM
hondafrk's Avatar
Default Re: zex compatibility ?'s (hondafrk)
Geez thanks for all the help guys
A special thanks to SMOOTHVTEC who I'med me with the answer I needed
Old Oct 28, 2002 | 03:20 PM
neveronlines2k's Avatar
They work on any fuel injected motor I believe. The brain in the purple box measers the voltage you'r car puts out, When its at full throttle it spray's the nitrous if it's not at that voltage no nitrous. Basically it will work on just about any late model ride. Here's there # if you want to ask them about a specific model 1-888-817-1008. Hope this helps.
Old Oct 28, 2002 | 04:00 PM
hondafrk's Avatar
Default Re: zex compatibility ?'s (stuckatworksi)
thanks for all the help man,
You are one of the only people who actually answered my question.
Thanks again
Old Oct 28, 2002 | 10:25 PM
Bleed Black's Avatar
Why dont you look on the zex site where it clearly tells you?
Old Oct 29, 2002 | 12:19 AM
97hb's Avatar
There are two generation Zex kits. One only works with 4 volts or higher tps at wide open throttle, the other is adjustable so it learns the tps in your car at wide open throttle. There should be a red button on the box indicating that it can learn.
Old Oct 29, 2002 | 03:03 AM
hondafrk's Avatar
Default Re: zex compatibility ?'s (97hb)
ok I see things clearly now about the compatibility. We just ordered a new zex kit and now I need to know what spark plugs we need.
Old Oct 29, 2002 | 03:28 AM
97hb's Avatar
Whatever your stock plugs will be, you need one step colder.
97hb's Avatar
BTW, this is for a mild shot up to 75 shot.
Old Oct 29, 2002 | 04:38 AM
Mista Bone's Avatar
D Tranny Guru
mostly depends on the fuel system...........
The second generation ZEX boxes came out to fit other makes, Honda TPS voltage was fine.
I'd suggest asking via email at zextech@zex.com
Joey or Matt should be able to overload you on info.
[Modified by Mista Bone, 8:38 AM 10/29/2002]
integrawow
Dec 21, 2007 07:02 PM
1BADEGDC2
Jun 27, 2007 02:54 AM
AL ASPIRATED
May 6, 2004 04:47 AM
KoRE
Mar 22, 2003 10:06 AM
Meateater
Aug 6, 2001 12:42 PM
