Will a Civic A/C compressor work on Integra LS?
Old Dec 24, 2013 | 02:19 PM
ClassyG's Avatar
Default Will a Civic A/C compressor work on Integra LS?
I have a bad compressor in my 1999 Acura integra LS, but a I can get a compressor from someone that has one from a 97 Honda Civic EX. Will I be able to install it on my integra without making any MODS?
Old Dec 24, 2013 | 02:28 PM
goldsy's Avatar
Don't quote me on this but if memory serves, you can put a d series ac compressor on a b series engine but you need the bracket off a 97-01 CRV to make it fit. Someone please correct me if I'm wrong on this.
Old Dec 24, 2013 | 05:23 PM
carlos8's Avatar
Default Re: Will a Civic A/C compressor work on Integra LS?
^^ Yes, but you have to use the CRV or Del Sol vtec mounting bracket.
Old Dec 24, 2013 | 07:21 PM
goldsy's Avatar
Ah yes, the vtec Del Sol torque mount bracket also works. The CRV ones should be a lot easier to come by though. I'm sure every junk yard has a first gen CRV sitting around.
Old Dec 26, 2013 | 07:10 AM
PaleAleS2k's Avatar
Recently put in a b18c1 in my hatch and for the a/c compressor to mount up I needed a p54 bracket for my particular application r/12 compressor. I tried the p30 bracket first and only two holes would line up on the compressor. Hope that helps you narrow it down.
Old Dec 28, 2013 | 09:01 AM
gato5254's Avatar
99-00 (b16)civic Si; 96-00 (d16) and the CRV (b20) use the same compressor. the Integra compressor (B18) is different. you can check on autozone, pepboys, what ever auto parts store. To install a d16 (civic) compessor you need the bracket from any B16 , B20, then you can just bolt it up the civic compessor to that B-motor
dijitalbuddhist
15
Mar 3, 2014 09:33 PM
genevievesalad
May 17, 2012 03:14 PM
EJ8 GSR-T
46
Sep 17, 2009 06:47 AM
arrojj
Jun 11, 2007 09:55 PM
freakin_eLRoD
Jun 29, 2004 10:13 AM
