CEL Code P0420 wont go away
Old 12-22-2013, 04:25 AM
ClassyG's Avatar
Default CEL Code P0420 wont go away
I have 1997 Honda civic EX that had a LS B18 motor swap from a 1999 Acura integra. The check engine light came on and gave the code P0420(Bank 1 below threshold). I had the cat converter replace and the code came back on. I aslo tried a new 02 sensor and it came back again. My question is does it matter which 02 sensor I get, or will the same one for a civic work on a integra? Not sure if they just giving diff readings.
Old 12-22-2013, 04:47 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: CEL Code P0420 wont go away
What kind of cat did you use?
Old 12-22-2013, 05:06 AM
ClassyG's Avatar
High flow universal cat converter that you have to weld on.
Old 12-22-2013, 05:17 AM
Technical Hero
That's more than likely your issue. You'll need to get a cat close to oem as possible. You could try a defouler and see if it can trick it.
Old 12-22-2013, 05:45 AM
ClassyG's Avatar
Ok I'll try it, but will it affect the air/fuel ratio by getting a different reading at all?
Old 12-28-2013, 09:17 AM
ClassyG's Avatar
I tried the spark plug Non-fouler and the CEL has not come back on since, thanks.
justdoinme23
06-15-2011 06:43 AM
Try2Live4God
05-20-2007 08:07 PM
MajinB
Honda Civic (2001 - 2005)
05-05-2006 08:41 PM
xjohnx
01-03-2003 09:14 PM
Quick Reply: CEL Code P0420 wont go away
