Transmission & Drivetrain Gearboxes, Differentials, Clutches
Honda D15B Dual V-tec engine with Autotranssmission need help in transmission wiring
Old Dec 24, 2013 | 12:46 PM
Mohsin Univrsal's Avatar
Default Honda D15B Dual V-tec engine with Autotranssmission need help in transmission wiring
Hi i need help i have honda civic 2000 PK recently planned to swap D15B3 with hx cvt tranny i got the P2j-j62 ecu with this swap so i swapped successfully engine starts well no fault codes but cvt tranny is not working even the tranny wires are not connected any where i need help regarding this where to connect these wires or does this cvt requires a tcm or what ? any help will be highly appreciated as i m very confused.
Old Dec 26, 2013 | 02:34 PM
94EG8's Avatar
Seagull Management
Default Re: Honda D15B Dual V-tec engine with Autotranssmission need help in transmission wi
The CVT has a separate TCM and is a royal pain in the ***. The easiest way to do it is find the engine and cabin harness from an HX CVT, otherwise it's easier to swap in a manual trans than it is to try to wire up the CVT.
Old Dec 27, 2013 | 12:26 PM
thanks for kind reply 94EG8
i actually don't have its TCM and i don't know about its TCM can you tell me which tcm it had to run this transmission i want to use it as a CVT Tranny i would like to try 1st.
Old Dec 27, 2013 | 12:36 PM
94EG8's Avatar
Seagull Management
You'll need a TCM for a '96 - '00 HX coupe or a JDM TCM from a 6th generation civic with the CVT/Multimatic trans. From what I remember the TCM goes on the opposite side of the car as the ECU in those cars.
Old Dec 27, 2013 | 12:49 PM
Actually i can't find the actuall TCM and i am from Pakistan so i can't get the dash wiring if you can help me to show the TCM so i can import it thanks
Old Dec 27, 2013 | 01:52 PM
94EG8's Avatar
Seagull Management
The control unit part number is 28100-P2M-327
#1 in the diagram http://www.hondaautomotiveparts.com/...IT+%28CABIN%29
You might be able to find someone selling one in the Honda-Tech marketplace (you can place a WTB ad in that section after you're no longer a trial member) I'm not sure of there are any Japanese importers in Pakistan but if there are perhaps they can get you the JDM version (multimatic TCM)
Old Dec 28, 2013 | 03:15 AM
ok thank you so it is 28100-P2M-327 which will work with P2j-j62 which is D15b 3 stage v-tec original ecu ? or i will have to get another ecu too ??
thank you
Old Dec 28, 2013 | 03:49 AM
today i got the CVT Transmission TCM unit code is 28100-PEJ-013
so can i use this in my setup infact this is honda CVT M4VA transmission tcm which i got with my D15b engine.
if i can use this i want tcm pinouts also if someone can help me thanks in advance
Old Dec 28, 2013 | 04:42 AM
94EG8's Avatar
Seagull Management
Yes.
Yes, you can use that TCM.
Old Dec 28, 2013 | 04:54 AM
Thanks but by the how can i use this i mean how to wire it with my ecu or i will be very thankfull if you can get the pinouts about this TCM and the P2J ecu too.
Old Dec 28, 2013 | 11:31 AM
kindly get me to the P2J-J62 Ecu pinouts
& 28100-PEJ-013 TCM Pinouts it would be highly help full for me
Old Dec 28, 2013 | 12:46 PM
94EG8's Avatar
Seagull Management
I'll see if I can find you something, no promises though.
Old Dec 29, 2013 | 01:56 AM
Thank you i am waiting
Old Dec 29, 2013 | 01:24 PM
94EG8's Avatar
Seagull Management
No luck on my end. I thought I might have access to something here. Perhaps someone else has pinouts.
Old Dec 30, 2013 | 02:20 AM
ok no problem by the way thanks for tying helping me
Old Jan 12, 2014 | 07:30 AM
Thanks to God i got succeed in my swap the cvt is working fine now what i did bought a complete dash wiring , cluster and shifter now glad to have this swap this is awsome with working all three stages .
the post is closed now thanks to 94EG8 who tried help me
CivicStar7
Apr 24, 2011 07:08 AM
Civic4less
Aug 14, 2004 11:40 PM
gardendalegti
37
Mar 30, 2004 12:24 AM
meams
Mar 8, 2003 03:37 PM
