hondata s300 downloading
Old Dec 23, 2013 | 05:32 PM
Yodi71's Avatar
Icon2 hondata s300 downloading
i got a p28 s300 im wondering if when using the program do i need to have the cd in the computer when trying to up load everything to my ecu?
i uploaded the program to my laptop now when i hit the program it wont open it keeps saying error? can some one help me out i need to get this ecu up and going so i can drive my car
Old Dec 24, 2013 | 06:19 AM
seelback's Avatar
Default Re: hondata s300 downloading
download the lastest version of smanager(s300 tuning software)from hondatas website. you dont need the cd. if may be your anti virus causing the error message. turn your interent off on your laptop and then turn your anti virus off and try to open smanager. if it opens then its your anti virus blocking smanager from opening. my anti virus does the same thing and I've tried everything to keep the anti virus open and run smanager but my anti virus is not happy. not all anti virus programs will do this.
Old Dec 24, 2013 | 01:19 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Most likely it is your antivirus program. Just had the same exact issue on a friend's car when I forgot my laptop and had to use his.
Old Dec 29, 2013 | 12:17 PM
Yodi71's Avatar
That worked but now when trying to plug the usb it won't show up on the laptop and I can't up load or do anything
Old Dec 29, 2013 | 12:24 PM
DO IT ON ALL FOURS
Check your COM ports. May have to clear them and reconnect.
Old Dec 29, 2013 | 05:35 PM
Yodi71's Avatar
i did everything they said from going threw the Device Manager and hondata doesn't even show up idk why
Old Dec 30, 2013 | 04:06 PM
Yodi71's Avatar
I have tried the process under the manual usb installation and the hondata s300 ecu is no where to be found under the universal serial bus controllers, or other devices this is the second computer I am attempting this on and the device itself is not showing up on the computers. The computer's were different windows one was an xp and the other was a windows 7. Is it possible that there might be something wrong with the ecu itself that is not letting it be recognized by the computers..... Also the ecu does not come up as a new device detected in the bottom right corner were all usb's connections would show up.
Old Dec 30, 2013 | 07:39 PM
DO IT ON ALL FOURS
Yes, it is VERY possible something is fried. If you are sure the S300 is fully seated, the cable is good, and you have power to the ECU I would personally send it out for inspection/repair. I am not sure of your abilities but you could always prep another ECU and test the board out as well. There is a tool to test all the solder joints on the male pins that has status LEDs built in.
Something I just thought of too - are you sure it is a legit S300? There are fakes running around. Check out Hondata's website on how to spot a fake.
Old Dec 30, 2013 | 08:40 PM
motoxxxman's Avatar
^this^
brand new hondata systems are only allowed to be sold by hondata dealers. anyone can sell a used hondata system though of course.
personally I suggest throwing the cd in the garbage. anytime you need s300 software, download it directly from hondata's website. that'll ensure authentic software, as well as ensure it installs the newest version right off the bat instead of installing a super old version and then patching it with an update which sometimes doesn't install properly.
hymn
Engine Management and Tuning
Feb 10, 2014 03:15 PM
turbodcxbro
Jan 9, 2010 11:31 AM
realis9
May 23, 2006 08:59 PM
98vsmferio
10
Feb 27, 2005 12:21 PM
Eyetattoo
Aug 1, 2003 07:15 PM
