D15B2 12mm and 14mm Crank Pulley Bolt
I'm looking to maybe buy a used motor and I keep getting asked what diameter the thread is on the crank pulley bolt. Any idea if this makes a difference? I think mine has a 14mm thread diameter but not sure and some of the motors out there are 12mm thread diameter.
1988 Civic 1.5L LX.
1988 Civic 1.5L LX.
I'm sorry for not specifying. The socket size to remove the bolt is a 17mm. The question is about the thread diameter. Apparently there are two versions.
M12 and M14 is what you meant, the metric size for the threads. I am not sure. Try and take the crank bolt to the parts store and check it out or look at a for sale listing online.
you're talking about the .944 & .865. I'm having the same problem. Did you find out? I have a 91 civic dx and I'm still searching which crankshaft goes this d15b2 engine .944 or .865
It was so long ago that I don't really remember.
I ended up buying a jdm engine which fit and worked well. Just a slight misfire at idle sometimes I couldn't figure out.
Someone over heated it and I gave up on the car mainly because of ac.
