Just bought it this morning
Old Dec 14, 2013 | 08:37 AM
tdmpc's Avatar
Default Just bought it this morning
$1200 Just needs a turn signal and it's ready to drive.
Maintenance:
Last year,
Passenger side axle
Radiator
Brake master cylinder
Emissions done in July, Passed
Last few months:
Driver side axle
Ball joint
Front rotors and pads
Brand new tires
Wheel alignment
"I've owned this civic del sol since 2009. I bought it with 125k on it, it has 175K now. The body is not in the best shape but mechanically this car has been taken care of with regular maintenance and always garaged. It is the automatic 1.6 VTec model. Targa-top, the seals are in great shape and don’t leak. The seats are very comfortable compared to the stock del sol seats. It averages 27-36 mpg depending on time of year and driving conditions. It has a clarion head unit with JBL speakers with ipod hook up. It has a wireless antennae because the stock ones are faulty. The check engine light is on for the IAC control valve, it has been replaced. The Exhaust was Replaced with a used one, not brand new but in good shape. All interior pieces are intact and working condition, very hard to find the whole interior in this good of shape." -Previous Owner
I just need to work on the body and then I think I'll get a new muffler but I'm not sure as far as the engine goes. I guess it's a B16 engine**d16z6** with automatic transmission, the check engine light is on for IACV which was replaced and the car cold starts like a champ and idles right at 2k. The next thing is new rear rotors, it already has new brake master cylinder brake pads and front rotors.
What are some suggestions for the engine?
Old Dec 14, 2013 | 08:41 AM
B_Swapped93's Avatar
Default Re: Just bought it this morning
Nope that's a D16 VTEC engine which appears to be an auto(I see a solenoid on the trans). You really can't do anything to it without it being a manual, so I suggest an auto to manual swap then a b-series engine of some sort.
Old Dec 14, 2013 | 08:45 AM
tdmpc's Avatar
OK so I have the 1994 Del Sol Si - D16Z6 with automatic transmission.
Old Dec 14, 2013 | 08:48 AM
cvcrcr99's Avatar
Yep... looks pretty stock to me. I would leave it that way IMO
Old Dec 14, 2013 | 08:53 AM
tdmpc's Avatar
Ya... I like the stock set up, I want to know what maintenance I should do to the engine though, if any...
Old Dec 14, 2013 | 08:56 AM
change the oil coolant and power steering fluid. then do a full ignition tune up which consists of: cap, rotor, plugs and plug wires. and if you're up for it bleed the brakes just to clear out the old nasty fluid. I'd also say fuel filter if it looks old. Save your money for paid I hate del sol's lol but I'm sure you could make it look nice
Old Dec 14, 2013 | 09:08 AM
purgat0ry's Avatar
Timing belt, belt tensioner, water pump, I can't stress this more.
Old Dec 14, 2013 | 09:16 AM
hmm I missed that in the op^
I though the last owner did them well in that case OP go OEM Honda you won't regret it.
Old Dec 14, 2013 | 09:43 AM
tdmpc's Avatar
Definitely needs it, the timing belt was whining a bit when she started up.
I'm trying to get the most for my money, so I'm looking at OEM kits. Any suggestions here? I'd like to buy as much at once as possible.
Old Dec 14, 2013 | 09:57 AM
go to the dealer you sometimes you find OEM Honda kits online look to spend about 150$.
Old Dec 14, 2013 | 10:04 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
These are my first things before all else if I don't know the history of them.
Everything else won't outright kill the car in under two seconds like the timing belt can.
Cheerio
P.S. All the fluids come right after.
Old Dec 14, 2013 | 10:13 AM
tdmpc's Avatar
Cheerio
I'm taking it home on Monday, and I'll have like 3 days off work, so i hope to get as much done as I can.
Old Dec 14, 2013 | 11:33 AM
boostlsveg's Avatar
Www.hondapartsnow.com good place to buy oem
Old Dec 14, 2013 | 12:54 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good luck, I'm also assuming you've had it safety inspected just to be sure your suspension and under carriage is in good shape. A tie rod end snapping or a ball joint giving up the ghost could be quite catastrophic too. The 100 bucks for the inspection is worth the peace of mind in my opinion.
I second the hondapartsnow website for OEM in the states. I use it to look up part numbers then go to the dealer here in Canuck land. Great resource.
Old Dec 18, 2013 | 05:18 AM
tdmpc's Avatar
Got it home - waiting on shipping
Old Dec 18, 2013 | 05:33 AM
VeganEJ8's Avatar
I'd also adjust the valves. I've bought 2 used hondas and each time my valves where out of spec
Old Dec 19, 2013 | 03:03 AM
tdmpc's Avatar
I'm next to nothing and I have to drive to work the new few days with no inspection and missing a turn signal. I have a week to get it inspected. CEL is on. Wish me luck!
Old Dec 30, 2013 | 02:16 PM
tdmpc's Avatar
As you can see it's a HID conversion kit the ballasts were just stuck in the front end so I removed them and put some $40 h4 4000k bulbs.
Spectre filter on OEM intake (airbox removed)
Bosch spark plugs + Oil change
Car is making it through the winter very dependable.
Waiting on rear brake rotors and pads to arrive.
After winter I'm looking at ebay I/H/E
Come summer I'm looking at body work and paint
Right now I'm looking at front right LCA professional replacement
Old Dec 30, 2013 | 03:33 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
I suspect you need to read this thread: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-your-guide-buying-quality-aftermarket-maintenance-parts-your-civic-3114911/
Old Dec 30, 2013 | 03:51 PM
Discosteak's Avatar
If you need a clutch line for a manual swap I have the whole factory clutch line that goes from the master to the slave.
Old Dec 30, 2013 | 06:57 PM
belairbrian's Avatar
Originally Posted by deschlong
I suspect you need to read this thread: https://honda-tech.com/forums/showthread.php?t=3114911
I was curious why Bosch plugs myself.
OP what seats are those? Don't look like del sol
Old Dec 30, 2013 | 08:31 PM
tdmpc's Avatar
NGK was out of stock
Not sure what the seats are out of but definitely not del sol.
Old Dec 30, 2013 | 09:54 PM
deschlong's Avatar
Loved
Community Favorite
Basically, if they don't have the brand of parts listed in that thread, don't buy them. Wait until they are available. This might be the best advice I can give you. Your spark plugs would have lasted a couple more days until the NGKs arrived.
Old Dec 31, 2013 | 04:44 AM
TekTekBesar's Avatar
OP mentioned that Maintenance:
Last year,
Passenger side axle
Radiator
I would assume that new coolant (radiator) and brake fluid (master cylinder) would have been replaced at that time of maintenance. Steering fluid change may or may not be needed (but is inexpensive). No need to do a tune-up unless it has a miss. If anything, maybe a set of plugs.. always start with the cheapest items first.
Nice score for $1200. Check IAVC threads here, should get it sorted out. As others have stated timing belt kit (water pump,tensioner, accessory belts, seals) for sure if no record of it in last 60K miles. New oil and PCV valve. Also a valve lash adjustment if no record in last 30K miles.
CKPerformance
14
Sep 12, 2007 10:54 PM
KyleVA
Feb 17, 2007 07:02 AM
kay_animation
Feb 3, 2003 06:04 PM
DC2_Jspec
Jul 21, 2002 12:20 AM
