GSR into EJ1 issues
Old Dec 8, 2013 | 07:43 PM
tico's Avatar
Default GSR into EJ1 issues
so im in the middle of swapping in a OBD1 gsr into my EJ1. and im having a few issues.
1st. passenger shock tower connectors i have a spare 2pin connector from the gsr harness. i have no idea where it goes
2nd. my radiator hoses. i have the b series hoses but they are bigger than my radiators outlets. is there hoses that are made for ths or do i need a 94-97 del sol vtec radiator?
Old Dec 8, 2013 | 08:54 PM
WhiteNeko's Avatar
Default Re: GSR into EJ1 issues
Did a LS swap into a friend EG using the B-series radiator hoses. I just got worm clamps and tighten them real tight. No leaks yet.
Old Dec 9, 2013 | 01:05 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
I'm wondering if the extra connector is for the abs system connection
And for the hoses. I've seen people slide PVC pipe onto the Ls hose and then a smaller pipe on the civic hose and attach the tubes together.
Or you can get a half size Ls radiator
Old Dec 9, 2013 | 03:24 AM
Fliptard's Avatar
get hoses for a 99-00 SI
Old Dec 9, 2013 | 06:22 AM
HondaPartsHero's Avatar
Technical Hero
Is your harness OBD2? If it is ignore the extra connector.
Old Dec 9, 2013 | 06:25 AM
Fliptard's Avatar
I do not believe an OBD2 Teg harness will work in a OBD1 civic. yea, it may plug in, but stuff is wired diff in OBD2
Old Dec 9, 2013 | 12:43 PM
crx_si-r's Avatar
If its an obd2 teggy harness it should be an extra 3 wire connector (Evap purge, and ckf wiring). Please post pics and I can determine better which harness you have. It's possible you may have an obd2 del sol harness
Old Dec 9, 2013 | 01:00 PM
94EG8's Avatar
Seagull Management
It's for the evap purge solenoid, that particular plug is unique to the GS-R. On all other Integra/Civic harnesses the evap purge wiring is part of the 3 large plugs, in the GS-R the IAB wiring is run there instead and the evap purge solenoid has it's own plug. If you don't have emissions testing you wont need this. If you have the original GS-R intake manifold and you would like the IABs (secondary butterflies to function, simply move pin A20 to A17 at the ECU.
That works, guys have been doing this for 20 years.
It does, it's also the easiest, cleanest way to drop an OBD2 engine in a '92 - '95 Civic or '94 - '95 Integra. See below:
Old Dec 16, 2013 | 07:40 AM
tico's Avatar
It is an obd 1 harness. So the extra plug is for the evap purge solenoid?
appelsos
11
Jul 11, 2011 06:24 PM
94-del slo gsr
20
May 31, 2011 08:57 AM
92CivicSiOEM
Dec 17, 2009 05:49 AM
Cuda
Jan 16, 2008 06:18 AM
