Can you cut off a t3 flange and weld on a t4?
Old Dec 8, 2013 | 10:00 AM
1lowek2007's Avatar
Default Can you cut off a t3 flange and weld on a t4?
Now, I know technically you can easily cut off a t3 flange and weld on a t4, but can you do it and it be just as strong as the previous flange? I would hate to do this and the turbo just fall off or something. Would it be better just to sell a manifold and buy a new one?
Old Dec 8, 2013 | 10:08 AM
10psiLsEf2's Avatar
Default Re: Can you cut off a t3 flange and weld on a t4?
What material is the manifold? Reason i ask is my cast manfoldhas a plate welded on. Its only been 1000 miles but no signs of leaks/falling off.
If its a steel manifold i wouldnt worry
Old Dec 8, 2013 | 10:10 AM
1lowek2007's Avatar
Its a stainless steel tubular manifold
Old Dec 8, 2013 | 10:12 AM
Alex L.'s Avatar
If it's welded properly, you should be fine. Make sure collector to flange fitment is prime before welding, though.
Old Dec 8, 2013 | 10:14 AM
1lowek2007's Avatar
Ok cool thank you
Old Dec 8, 2013 | 04:24 PM
10psiLsEf2's Avatar
Youll be alright
After having the plate welded on. Check the surface for trueness with a straight edge.
You dont want it warped.
BOOSTEDk24a4
Jun 25, 2007 09:51 AM
eg2phosizzle
Welding / Fabrication
Mar 29, 2006 07:09 AM
EKB18BPR3
Jul 8, 2004 05:26 PM
d98clturbo
Dec 27, 2003 09:39 PM
boosted3g
Jul 19, 2002 06:39 PM
