problem, change cvt to manual
Old Dec 2, 2013 | 03:16 PM
xkor3_m3talx's Avatar
Default problem, change cvt to manual
Hello, I'm from Peru, I have a EK3 D15b non vtec(jdm), originally came with cvt transmission .. I decided to switch to manual .... but the car works usual ... but consumes too much gas ... and when I turn it on and heats the rpms down to 750 -600 ... but if I'm in the car ... and then I stop in neutral ... accelerates and stays at 1000rpms ... if I turn off and turn on the car again ... the rpms drop to 750-600 ... I have the more complicated the p2c ecu ... I want to know if anyone had a similar problem .. I have also connected the ecu of transmission cvt ... that if I disconnect the car accelerates to 2000 rpms
Old Dec 2, 2013 | 04:48 PM
94EG8's Avatar
Seagull Management
Default Re: problem, change cvt to manual
You'll need to get the manual ECU for your engine. You may also need to rewire the idle air control valve (IACV) if they're different between the auto and manual version.
Old Dec 3, 2013 | 04:38 AM
thank you very much for your answer ... but you know what ecu code should I get?
Old Dec 3, 2013 | 04:53 AM
axis11's Avatar
ECU code for manual trans is P2C-Y01. I have 1 extra, but it costs a lot to ship from me to you. Search online, i've seen those ecu posted on ebay before. Or go and check your local junkyard.
fryman
10
Mar 24, 2023 01:40 PM
vy3tnamezz
Engine Management and Tuning
10
Sep 25, 2009 08:35 PM
ywsek
Oct 13, 2006 07:14 AM
E36 Guy
Jan 17, 2006 07:41 PM
rleroy
11
Aug 29, 2005 10:07 AM
