do b20/ls nonvtecs usually run higher egts?
Old Dec 2, 2013 | 03:14 AM
blackeg's Avatar
Default do b20/ls nonvtecs usually run higher egts?
Ive noticed now that both of the b20 motors ive had seem to run cruising egts a good amount higher than the vtec motors.
Im seeing 700-720c for the nons and would see 650ish for the vtec. This is with a gsr5th gear for all motors. Ive tried adding a few more degrees timing it helped a bit as well a bringing afr into the mid14's down from about 15:1.
prjdmek
Mar 10, 2010 09:24 AM
poppypizza
Nov 8, 2007 07:48 PM
IntegraGSR(-1)
Jul 10, 2005 09:52 PM
cvclover
Dec 25, 2004 03:37 PM
lopezvic03
Jun 23, 2004 12:24 PM
