Honda Civic 2000 won't start
Old Nov 30, 2013 | 07:52 PM
PSHuertas's Avatar
Default Honda Civic 2000 won't start
My Honda Civic was starting fine everyday. Yesterday, it cranked over, but wouldn't start. Checked my fuses; all good. Checked my spark; no spark. I replaced the coil with a used one. The car started three times only. Now it doesn't start again. Can anyone give me an idea as to why it started and now it doesn't.
Old Dec 1, 2013 | 03:48 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Honda Civic 2000 won't start
Welcome to the Accord Forum...
When you turn your key to ON can you hear the Fuel Pump prime? If not it may be your main relay is failing.
Old Dec 1, 2013 | 07:54 AM
PSHuertas's Avatar
Yes, I do hear my fuel pump prime but still no spark. Any other suggestions? Also, can you tell me how many cables are suppose to bring power from the computer to the distributor when you are cranking?
Old Dec 1, 2013 | 07:57 AM
ej6-b16's Avatar
it could be the plugs wires or the dizzy i would check all of them
Old Dec 1, 2013 | 08:05 AM
PSHuertas's Avatar
What's the dizzy? Can you explain a little bit?
Old Dec 1, 2013 | 09:36 AM
Zak325's Avatar
Dizzy=distributor. It is the piece that all the spark plug wires are plugged into. It basically is told by the camshaft when to send spark to which spark plug for which piston
Old Dec 2, 2013 | 06:18 PM
PSHuertas's Avatar
I changed the distributor. Car started right up. Thank you.
Old Dec 2, 2013 | 06:25 PM
dirty-rob's Avatar
more than likely it was the igniter inside the dizzy,real common
votex5
Jun 13, 2013 11:51 AM
oldmc
Sep 2, 2011 10:45 AM
DelSlowmo
61
Feb 12, 2009 07:50 PM
Keno20
Jan 26, 2009 10:10 PM
sikwitit
Apr 10, 2008 05:53 PM
