Transmission & Drivetrain Gearboxes, Differentials, Clutches
S80 Tranny won't go in to gears.
Old Nov 28, 2013 | 08:04 PM
jecapeal's Avatar
Default S80 Tranny won't go in to gears.
i was driving my JDM DC2 SiR-G b18c with typeR S80 LSD gearbox and i missed 2nd gear. and for a few days the gears felt a lil sticky like somthing was bent. but still shifted into gear ok. then one day i was driving home and i went to go into 4th gear and it went in like butter no friction at all, then i i downshifted to 2nd to take corner and there was no gears and the shifter went all loose with no gear pattern. it didnt make any noise at all. i looked and its not the shift linkage under the shifter or the bushings. and the clutch still works i can hear it engage when its running. but i wanna know what broke?. what could it be?
Thanks for your help.
Old Nov 29, 2013 | 01:49 AM
92civiceg9gsr's Avatar
Default Re: S80 Tranny won't go in to gears.
Most likely the sh*tty stock Honda shift selector in the trans broke.
Old Nov 30, 2013 | 07:25 AM
jecapeal's Avatar
hey guys come on, no one knows?
Old Nov 30, 2013 | 05:15 PM
slowcivic2k's Avatar
The shift selector or "shift piece" inside the transaxle is broken or severely damaged. Being forceful on the shifter will break that piece.
Old Dec 1, 2013 | 12:53 PM
Emeraldbomber's Avatar
Yep. It's broken or bent.
Old Dec 2, 2013 | 05:33 PM
jecapeal's Avatar
Thanks slowcivic2k, the problem is already solved, and it was broken selector
Hephro.T
Sep 27, 2016 11:22 PM
spooncivic1
Jan 8, 2006 07:14 PM
crazivi3tdude
May 11, 2005 11:28 AM
coachkellum
Sep 9, 2004 02:03 PM
