Jumpy speedometer: VSS or cluster?
Old Nov 24, 2013 | 11:58 PM
Outrun's Avatar
Default Jumpy speedometer: VSS or cluster?
I checked with the local Honda dealership and a new VSS for a 1994 Civic is over $100 (forgot exact price). Local Napa store can get a third-party VSS for about $50 same day if ordered by 10am as they don't have one in stock.
From the video, is the jumpy speedometer from a bad VSS or a bad cluster? I'm not sure if a bad VSS or a bad cluster results in different or similar jumpy speedometer needle behaviour.
I don't need to change it right away as it doesn't happen that much, though it seems rough roads sometimes trigger the jumpy needle. I'm going home for Thanksgiving so I'll try to swap out the VSS from a family member's '95 Civic to see if the problem still persists.
Old Nov 25, 2013 | 01:24 AM
Simas Vi's Avatar
Default Re: Jumpy speedometer: VSS or cluster?
My case was similar and was caused by the speedometer. I just changed all speedometer to other and problem was solved.
blinger
11
Mar 26, 2024 08:08 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
hondaboy4life
Oct 9, 2006 09:35 AM
Built B18ABorC
Oct 26, 2004 05:41 PM
mc
Apr 19, 2004 07:58 PM
