Catch can in place of PCV, hose confusion.
Old Nov 18, 2013 | 08:07 PM
B_Swapped93's Avatar
Default Catch can in place of PCV, hose confusion.
I understand a catch can set up on a n/a dd car is pointless, which this set up is not going on. My questions are in total I will need 4 hoses 2 tapped to the VC and 2 going to the block(i'm letting it drain back). my question is where on the block do the 2 lines go ? I know I need fittings and a pcv block off(all comes in the kit). do I have to do anything special to install the 2 block fittings ?. my TB/intake gets gummed up pretty badly and i've been having issues with my pcv box leaking etc.
compression is sold on the car also but I'm still getting lots of blowby ?
looking at the BWR kit
Old Nov 19, 2013 | 01:16 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Default Re: Catch can in place of PCV, hose confusion.
I would run the lines to the top of the oil pan and into the oil pressure port..?
Old Nov 19, 2013 | 07:49 AM
killer833's Avatar
why not just get the prelude block fittings and use those with a ebay catch can.
Old Nov 19, 2013 | 07:54 AM
NZXTInerTia's Avatar
Why would you ever let that junk drain back into the block? It seems fairly counter-productive to me.
Old Nov 19, 2013 | 09:07 AM
kaycee_00's Avatar
x2 ^ the catch can isn't going to fill up and over flow as long as you drain it every time you do an oil change.
The fittings go in the back on both sides of the oil filter like this
And you only need the right size allen head thingy to get the old ones out, mine were in pretty good so I used a short breaker bar to get them loose.
As for the freeze plug for the pcv hole, you just hammer it in place I think. My motor didn't have one so I didn't have to use it.
Old Nov 19, 2013 | 11:34 AM
Thank you kaycee for the pics, haven't been to the garage in a while since i'm waiting for parts lol. As for the drain back I heard about possible oil starvation by not having that option . so 2 bung's welded to the VC and 2 coming off the block via the fittings.
the car is a time attack car so it see LOT'S of sharp turns and sustained high RPM's.
Old Nov 19, 2013 | 03:07 PM
kaycee_00's Avatar
A baffled oil pan will correct that issue for the most part lol not a drain back for the vapors that get collected into the can. Just make sure the can is mounted in the highest spot possible and you shouldn't be filling it up with pure oil.
Old Nov 19, 2013 | 04:59 PM
moroso baffled pan enroute
found the 3 block plugs separate from IPG but to confirm I will need 2 bungs welded on the VC 4 lines in total.
Old Nov 20, 2013 | 02:52 AM
kaycee_00's Avatar
You should be set then, what catch can are you going with?
Old Nov 20, 2013 | 05:17 PM
Got a deal on a Sheepey built one ! lol
Honderachinaldo
Jul 16, 2019 08:28 PM
acuralovar
Oct 20, 2008 05:00 AM
HiProfile
Jul 3, 2005 07:13 AM
bleedblue94
Sep 3, 2004 08:49 PM
12 oz.
Jul 18, 2004 08:23 PM
