01 Accord botch front brake job.
Old Nov 15, 2013 | 08:36 AM
laloquera916's Avatar
Default 01 Accord botch front brake job.
I just swap out my buddy's front rotors and pads. Did the routine procedures, no broken parts or issues. Today he calls me, he hears a laud nose and scratching metal noise.
Did I miss something here? Help help.
Old Nov 15, 2013 | 09:23 AM
GhostAccord's Avatar
Default Re: 01 Accord botch front brake job.
Well according to the information you have posted, it seems as though you did the brake job correctly and nothing was broken. So I'm not sure what there is that you could have missed?
You will have to take a look at the car and see if there is something wrong with the newly installed brakes.
Old Nov 15, 2013 | 10:50 AM
Im thinking the dust cover may or can be rubbing against the rotor on the back side. Can the pads get stuck open or shut on the track? I did pump the brakes till they got pressure build up.
Old Nov 15, 2013 | 01:10 PM
NZXTInerTia's Avatar
Well, did you spray the rotors with brake cleaner and give them a good wipe down first? You can also inspect the "clips" that keep the pads tight and in place, sometimes they can become bent or damaged and rub like that. Also check for proper lubrication on the slide pins.
Old Nov 15, 2013 | 05:37 PM
holmesnmanny's Avatar
Sounds like backing plate rubbing on rotor. Just needs to be bent back out. Pretty common issue.
Old Nov 15, 2013 | 08:19 PM
I double check everything in my mind all day, turns out the passenger dust cover was rubbing and clear both sides a bit back.
Thanks folks
Old Nov 15, 2013 | 08:28 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
lol this is why you are supposed to test drive the car before giving it back.
EGBuddy
Apr 19, 2006 06:46 AM
Poopie
Jun 25, 2004 07:03 PM
yaya
May 19, 2003 08:18 PM
ernald711
Mar 18, 2003 05:38 PM
96accord
Oct 8, 2002 02:28 PM
