b7 block and z6 head mini me - IAT CEL code
Old Nov 15, 2013 | 06:42 AM
lilboxx's Avatar
Default b7 block and z6 head mini me - IAT CEL code
i have a 94 dx b7 block and z6 head all together i put my p28 ecu in and i get engine code for the iat sensor which worjed great before just wondering if using the old b7 ecu will harm anything just to test and see if its the ecu problem ive gone thru with a multimeter and everythi g checks out but the code doesnt go away
Old Nov 15, 2013 | 07:55 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b7 block and z6 head mini me - IAT CEL code
What color are the wires going to the plug on your IAT?
Old Nov 15, 2013 | 08:27 AM
lilboxx's Avatar
red /yellow + green/white -
Old Nov 15, 2013 | 09:59 AM
Technical Hero
Old Nov 15, 2013 | 10:24 AM
lilboxx's Avatar
yep thats the same manual i was going by but the only other ecu i have is the stock dx one which isnt a p28
Old Nov 15, 2013 | 10:47 AM
Technical Hero
you can try it and see if the code goes away, if it does you know the culprit. I'd just double check to make sure the IAT, IACV and EVAP plugs have the correct colors. Mixing them up its possible to fry the ECU. Here's a link to check out the colors:
https://honda-tech.com/forums/showthread.php?p=48795245
Old Nov 15, 2013 | 11:04 AM
lilboxx's Avatar
thanks ill double check when i get home
Old Nov 16, 2013 | 12:43 PM
lilboxx's Avatar
well everything's hooked up right light it should be
Old Nov 16, 2013 | 01:49 PM
Technical Hero
Did it do the same thing with the other ecu?
Deadlock281
Sep 4, 2008 07:23 AM
d1nki
Nov 7, 2007 08:47 PM
ProjectEG8
11
Oct 28, 2007 01:00 PM
0334973
Mar 23, 2007 06:41 AM
HatchMo
Jun 8, 2005 09:48 PM
