2000 Ek coupe low compression ISSUE
Old Nov 13, 2013 | 03:21 PM
Paverboy's Avatar
Icon2 2000 Ek coupe low compression ISSUE
Hey guys i have a 2000 honda civic DX coupe, It was low compression in cylinder 1 &3 , I just replaced the plugs and wires, The motor has 212k on it. I am the second owner of the car. My machanic told me that 1&3 have 78psi and 2&4 have 185psi. What could i do to fix this? and What do you think is wrong.
Old Nov 13, 2013 | 03:27 PM
EJ Rocket's Avatar
Default Re: 2000 Ek coupe low compression ISSUE
It could be any number of things: Burnt valves, bad headgasket, bad piston rings. Does it burn a lot of oil? Does it use coolant?
Old Nov 13, 2013 | 03:45 PM
B_Swapped93's Avatar
burnt/warped valves most likely if it's THAT low. Bad HG won't cause number's that low....rings would have to be completely shot for it to be that low again. I'll bet you replaced the plug and wires cause it has a rough idle/slight mis, time to put new valves in not a hard job just some what time consuming.
Old Nov 14, 2013 | 02:20 PM
Paverboy's Avatar
What Valves Are burnt? I would like some help through this. any tips or derections?
Old Nov 14, 2013 | 02:50 PM
only way to tell is a leakdown test but it's easier to replace all of them at once.
Old Nov 14, 2013 | 02:58 PM
Paverboy's Avatar
ok thanks man soo much, Do you happen to have a refrence I could go to, for directions to do this on my D16y7
Old Nov 14, 2013 | 03:05 PM
requires puling the head then the rocker arm assembly I don't have any links to a DIY. you could just bring the head to a garage and have them do it.
swain2894
19
Apr 27, 2014 12:07 AM
fasil911
Jan 30, 2007 06:09 PM
RGoose18
May 21, 2004 10:13 AM
allmotorls95
Apr 24, 2003 04:37 PM
lsvtec42
Dec 6, 2001 12:39 PM
