need help with codes 52 and 45
ok so i swapped a b16a into my eg everything seems fine i have a p30 supposedly chipped which i doubt but the problem is that i have 2 codes
i have a code 52 since there is 5 fast and 2 slow then second is easy its code 45 since it says its running rich or lean but that i dont have a problem since i can fix but i have no idea what code 52 is any help would be appreciated
thanks in advance
thanks in advance
**By counting the number of flashes, you can decipher the CEL code**
A LONG flash (1 second) is 10
A SHORT flash (0.5 second) is 1
For example, two long flashes followed quickly by two short flashes would be code 22. If there is more than one code, each code will be separated by a 2.5 second gap.
Yea i know i got mxed up reading the codes i know how to fix them i need a jdm tb gasket and my buddy made me one but didnt have a diagram so i need to make a a new one and the other one is the o2 sensor just havent had time cause of work again sorry and thanks for the fast input
eg crunkmonster
Jan 14, 2004 03:29 AM
a normal TB gasket works just fine....
