B18 Crankshaft Timing Belt Gear Question
Old Nov 10, 2013 | 05:51 AM
tuboflard's Avatar
Default B18 Crankshaft Timing Belt Gear Question
So I was helping my friend dissemble his B18C5 GSR engine. We had the block on a stand and we were taking off oil pump/crank. There is a timing belt gear on the crank with a key. Behind that there is another what looks like toothed wheel. I am at my house now so I don't have a picture. But what is that wheel behind the gear. I broke a tooth on it when taking it off so... do i need to replace it? Or do i not worry about it.
this is the best image I could find. If you see the wheel behind the gear.
Old Nov 10, 2013 | 06:15 AM
TheRealTegger's Avatar
Default Re: B18 Crankshaft Timing Belt Gear Question
You appear to be referring to the Crankshaft Fluctuation Sensor (CKF sensor).
Does this look like what you have?
https://honda-tech.com/forums/tech-misc-15/ckf-sensor-crankshaft-speed-fluctuation-help-833005/
boostedteg4dr
Feb 25, 2014 08:39 PM
j4s0n1337
Feb 15, 2012 03:07 PM
Svery
Feb 8, 2010 01:21 AM
jjipson
Dec 4, 2009 05:00 PM
aut0tek
Nov 13, 2004 02:24 PM
