Random jumping idle
Old Nov 9, 2013 | 06:03 AM
Youshady2's Avatar
Default Random jumping idle
Every ounce in a while my car starts idling funny jumping from 0 to 2 rpm at a dead stop, I checked everything and its all on point, when this happens the check engine light comes on but it goes away if I turn the car off and on, I was messing around for hours today decided to pull the CPU and open it up, this is a 95 integra gsr with a b18c5 Motor and Japanese gsr tranny, the CPU I have is off a 95 gsr and I haven't had any problems with it in the last few months, when I poped the cover off the CPU this is what I found, there is a lil burn mark if you can see it.. Could this be causing my random check engine lights and funny idle if so do you think a p28 would do me justice I'm short on cash and my frind got one for 80 bills, my setup is b18c5, Japanese gsr tranny, skunk 2 intake manifold, and full magna flow exhaust with type r headers, any help would be apreciatted.
Old Nov 9, 2013 | 08:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: Random jumping idle
My guess is it is a problem with the ECU/ECM, [CPU] burn marks indicate a short or poor ground, either way it needs to be fixed before another ECU/ECM is plugged into the system. 94
Old Nov 10, 2013 | 04:55 AM
Youshady2's Avatar
Do you think that lil burn would cause my random check engine lights and jumping idle?
Old Nov 10, 2013 | 05:27 AM
TheRealTegger's Avatar
That "little" burn mark is a very bad thing: it means you've likely got some kind of short somewhere.
The component right next to the scorched pins also appears to be burned; it's hard to tell in your blurry, low-quality photo.
The damage seen in the photo could definitely cause your problems. I would not swap in a new ECM (not "CPU") until the cause of the short is found and fixed, otherwise you stand an excellent chance of wrecking the replacement ECM.
Old Nov 10, 2013 | 07:54 AM
fcm's Avatar
fcm
Old Fart
What TheRealTegger said. 94
babohyungjin
Sep 19, 2010 07:43 PM
babohyungjin
Mar 25, 2010 01:38 PM
xxi2icexx
Dec 9, 2008 07:48 AM
jDmek9tec
Nov 29, 2007 11:42 AM
1Bar GSR
Aug 4, 2004 07:19 PM
