Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
noob question where can u drill for the turbo to run oil
Old Nov 10, 2013 | 01:10 AM
dungsta's Avatar
Default noob question where can u drill for the turbo to run oil
i want to set up for turbo but dont know where to drill the holes for it.. there should be 3 oil lines.
where can u drill to get oil to the turbo?
1 is oil pan
i seen one on the head?
where does the other 2 go? not really planning to go all out n drill holes into the bottom block though?
cant really find what i need on the internet.
btw planning to build a poor mans turbo. k20
Old Dec 24, 2013 | 12:34 PM
97emsedan's Avatar
Default Re: noob question where can u drill for the turbo to run oil
The oil supply lines for the turbo come from an adapter that sits on your oil filter mount ( the filter still goes there, but it sits on the adapter. The oil drain from the turbo back to the sump is what you need to locate and drill for a fitting. You should only need two oil lines. the third is a vacuum line for the wastegate...
Old Dec 24, 2013 | 12:58 PM
Fliptard's Avatar
by stating everything you said, the way you said it, and not knowing one of the main things in adding a turbo. I would stay away from boosting or any major upgrades to you car until you gather much more knowledge and experience (in other ways than ruining your car/motor)
Or pay a professional do your work.
wunest
Apr 8, 2010 10:12 AM
bubbleboy22
Jun 18, 2007 03:26 PM
2SlowDC
Aug 25, 2004 12:55 PM
B18c1CivicTurboed
Jun 3, 2003 08:33 AM
15psi of fun
Feb 4, 2003 10:17 PM
