LS-VTEC situation
Old Nov 6, 2013 | 05:44 PM
johnnyrexc's Avatar
Default LS-VTEC situation
Hello honda tech glad to be here,i recently purchased a 95 civic ex with a b18b1 with a 99 b16 head. The car runs and i drive it everyday the problem is it needs a new wire harness because its all cut up there is no wire for vtec or the oil sending switch next to the solenoid. My quedtion is simple what is the best route to make my motor run good without and problems? What harness? What ecu? i searched for 4 hours before i made a thread please help me
Old Nov 6, 2013 | 05:47 PM
johnnyrexc's Avatar
Default Re: LS-VTEC situation
I dont know anything about what the car has now because i bought it running like this if i wanted to get a new harness and ecu which should i use? B18b1-99 b16 pr3 head in 95 civic ex coupe
Old Nov 6, 2013 | 05:59 PM
johnnyrexc's Avatar
Trying to order what i need tonight any help would be great
Old Nov 6, 2013 | 06:17 PM
carlos8's Avatar
if you want OEM you can buy a 95ex harness and extend the vtec wires, because the sohc have the solenoid in the back of the head. But is very straight forward.
If you have the money always a rywire it's awesome!!
For ECU a p28 chipped with whatever program you Prefer.
What ECU you run actually?
Old Nov 7, 2013 | 01:18 AM
johnnyrexc's Avatar
Isnt the 95 ex harness obd1 how would that work with a obd2 motor ? This is very confusing to me
Im not sure which computer i have or which one to use
The only thing i know is its a b18b1 and i 99 pr3 head
The car runs now with no issue no cel or anything but on the acutal harness thats on the some wires are not connected to anything and either the vtec solenoid wire was cut or there is none
Any help counts thanks
Old Nov 7, 2013 | 04:56 AM
Chriser0's Avatar
If it can run to red line with no CEL theres no issue with VTEC.
Old Nov 7, 2013 | 05:22 AM
carlos8's Avatar
Easy, Run a obd1 dizzy and alternator, even a complete intake manifold with IAT cause the 99 b16 no have it.
For the ECU take it in your hand and see in the side there's a sticker with numbers 5digit then 3 then 3 more post it.
You are saying the vtec solenoid and pressure switch are disconnected and no CEL and the car run without issue?
Old Nov 7, 2013 | 06:44 AM
johnnyrexc's Avatar
Ok my ecu is a p75 ls ecu? The cel light is not ,maybe the light is out..it stops reving at 7200..so i have no future problems im changing the harness and ecu.
How do i know whats obd2 or obd1 things mybe mixed up..the harness that goes into the p75 doednt have a jumper so maybe its a ls obd2 harness with a obd2 ecu..whatever it is i want to change it to get the most out of my lsv
Old Nov 7, 2013 | 07:01 AM
kyden's Avatar
it's a stock p75 so yes it will cut off at 7200. that's normal. get that ecu chipped.
it's not going to be an obd2 harness. that's not possible. and if there's no jumper harness it's not an obd2 ecu either.
Old Nov 7, 2013 | 07:03 AM
instrument's Avatar
obd integras and 92 95 civics have the same harness connectors, you can swap an obd2 integra motor into it with no jumper as long as you use an obd1 ecu.
I know because I have one in my vx.
id think youd need an obd 2 gsr harness, but you would have to verify that your motor is in fact obd2.
Old Nov 7, 2013 | 07:28 AM
carlos8's Avatar
As kyden said, Get the ECU chipped and vtec converted.
In the FAQ's there is a thread on how to do conversions of obd's and explain the different plugs colors.
For start check your distributor number in the side of it, this tell what obd it is.
Old Nov 7, 2013 | 08:50 AM
johnnyrexc's Avatar
I really appreciate all the quick feedback.
With that being said.the harness that's on here now i would like to change because its all cut up and looks like ****..what harness would bolt right up? Would i have to rewire things like injectors,dizzy,vtec solenoid and what not? And should i just get a p28 ecu? Thanks
Old Nov 7, 2013 | 09:03 AM
carlos8's Avatar
before bought anything you need to verify what obd are your accessories.
I.E. injectors, dizzy and alternator.
If you have obd1 acc. go with 92-95ex.
If is obd2 follow the recommendations from instrument.
Old Nov 7, 2013 | 09:35 AM
johnnyrexc's Avatar
Thanks man I'll look into it
Old Nov 7, 2013 | 09:50 AM
johnnyrexc's Avatar
Any idea how to know if the accessories are obd2 or 1 this is all very confusing to me i used to have a 98 gsr integra everything was so simple. Im assuming the kid who had the car before me got a 96 integra motor tranny and harness from a junk yard and did the lsvtec kit so i doubt think the accessories are obd1 but then again i do not know
Old Nov 7, 2013 | 10:35 AM
carlos8's Avatar
dizzy check numbers on the edge of the body to I.D.
Alternator
obd1 = Round plug
obd2 = square plug
injectors
grey plugs with wire clip obd1
black plug with plastic tabs on the sides obd2
https://encrypted-tbn3.gstatic.com/i...wBW0V_DKsQIfwm
https://encrypted-tbn3.gstatic.com/i...9abibKE5rzTdDp
Old Nov 7, 2013 | 12:26 PM
johnnyrexc's Avatar
Your the man I'm checking now
Old Nov 7, 2013 | 12:33 PM
johnnyrexc's Avatar
The dizy says td-68u 3708,obd2 alternator,and my injector clips are grey but look spliced
Old Nov 7, 2013 | 12:50 PM
carlos8's Avatar
TD-68u = GSR obd1
obd1 injectors
but obd2 alternator.
Try to check where you have a spliced plug wherever in the dizzy or alternator.
My Opinion, if all is obd1 less the alternator go with a 92-95ex harness and make the little changes needed to fit.
In the alternator find a obd1 or splice your already obd2 plug.
Old Nov 7, 2013 | 01:41 PM
johnnyrexc's Avatar
Thanks for all the help Carlos
illassek9
Sep 29, 2007 08:57 PM
I think I can
Sep 4, 2007 04:52 PM
xtreme412
Jan 10, 2006 05:53 PM
kihun_cha
Dec 14, 2005 12:23 PM
b1698civicex
Jan 26, 2004 02:33 PM
