D16z6 engine mount driver-side to block missing???
Old Nov 3, 2013 | 08:59 AM
EG-SIXV-TEC's Avatar
Post D16z6 engine mount driver-side to block missing???
i finish build a d16z6 engine that will need to be swapped into a EG vx.
current engine d16z6
the motor was missing the driver side engine mount bracket timing belt side. bolted to the block. i want to make sure i got the correct engine mount.
ARE D16z6 engine mount 3 bolts or only two bolts? confusion i got a used set of mounts installed it, but want to make sure if its supposed to be 2 bolts or 3 bolts?
here is the pictures
1st pic installed with the engine d16z6 a 2 bolt version.
2nd pic installed with the d16z6 engine a 2 bolt version.
3rd pic i got online looks like a 3 bolt version bracket.
4th pic i got online looks like a 3 bolts version bracket.
d16z6 2 or 3 bolts version ???? side mount helpp.....
Old Nov 3, 2013 | 10:22 AM
B_Swapped93's Avatar
Default Re: D16z6 engine mount driver-side to block missing???
2 that last pic is an integra mount
Old Nov 3, 2013 | 10:25 AM
NewCarScent's Avatar
Both mounts can be used, just need the corresponding bracket to the block. I've had D series engines with both type of mounts on them.
Old Nov 3, 2013 | 11:44 AM
HondaPartsHero's Avatar
Technical Hero
Old Nov 3, 2013 | 11:58 AM
speedooo's Avatar
They came with both. Integra/Civic mounts are identical, b and d series. Just make sure you match the post and mount.
Post Re: D16z6 engine mount driver-side to block missing???
Originally Posted by HondaPartsHero
so d series mount im using i should be good then????
the one i am using can i use on my EG/
the part that confuses me is that ive seen some people engine has the longer bolt one on the d16z6 vtec one.
my current d15z1 in my eg now has the aluminum 3 bolt one. bolted on the mounting.
if i install the mount with the 2 bolt one and use the 2 bolt mount will it bolt up into the EG mount? will the angle or alignment change if i install the motor?
will the angle or some sort change
Old Nov 4, 2013 | 07:40 AM
so either one will work???
does the d16z6 originally came with the 2 bolt ones or the three bolt ones. im using the 2 bolt one???
Old Nov 4, 2013 | 08:44 AM
94EG8's Avatar
Seagull Management
Yes, you just have to use a matching post mount and rubber mount together.
It depends on the year. '92 - '93 use the two post steel version, '94 - '95 use the 3 post (somewhat misnamed as it's actually 2 studs and a bolt) aluminum Integra style mount. The same goes for the D15Z1 (VX) engine.
Old Nov 4, 2013 | 07:54 PM
my 1995 vx motor originally has with the stock motor d15z1 with the 3 bolts type aluminum mount. but i sold the whole swap already a while ago.
i will use the 2 post mount bracket on the z6 with the 2 post steel version mount.
since mine came out 1995 civic vx original with a 3 point.
will the z6 2 point bracket/2 point steel mount sill bolt up without problems??? does the year matter will the steel 2 point still work????
pls let me know thanks..
Old Nov 5, 2013 | 02:48 AM
94EG8's Avatar
Seagull Management
Yes, all that matters is that both parts match.
Old Nov 5, 2013 | 06:42 PM
so the year 1995 vx chassy.
wont bolt up if i use the 2 point posts on my engine
Old Nov 6, 2013 | 02:57 AM
94EG8's Avatar
Seagull Management
Yes it will. The year of chassis is irrelevant, they're all the same. Just the two mounts have to match, steel mount with 2 post bracket, and aluminum mount with 3 post bracket.
fryman
Dec 9, 2013 05:38 PM
singlecammin
Feb 22, 2011 04:58 PM
dynomax27
Aug 13, 2003 02:28 PM
one11racing
Jun 10, 2003 02:33 PM
