D16z6 engine mount driver-side to block missing???
i finish build a d16z6 engine that will need to be swapped into a EG vx.
current engine d16z6
the motor was missing the driver side engine mount bracket timing belt side. bolted to the block. i want to make sure i got the correct engine mount.
ARE D16z6 engine mount 3 bolts or only two bolts? confusion i got a used set of mounts installed it, but want to make sure if its supposed to be 2 bolts or 3 bolts?
here is the pictures
1st pic installed with the engine d16z6 a 2 bolt version.
2nd pic installed with the d16z6 engine a 2 bolt version.
3rd pic i got online looks like a 3 bolt version bracket.
4th pic i got online looks like a 3 bolts version bracket.
d16z6 2 or 3 bolts version ???? side mount helpp.....
Re: D16z6 engine mount driver-side to block missing???
Both mounts can be used, just need the corresponding bracket to the block. I've had D series engines with both type of mounts on them.
They came with both. Integra/Civic mounts are identical, b and d series. Just make sure you match the post and mount.
so d series mount im using i should be good then????
the one i am using can i use on my EG/
the part that confuses me is that ive seen some people engine has the longer bolt one on the d16z6 vtec one.
my current d15z1 in my eg now has the aluminum 3 bolt one. bolted on the mounting.
if i install the mount with the 2 bolt one and use the 2 bolt mount will it bolt up into the EG mount? will the angle or alignment change if i install the motor?
will the angle or some sort change
Seagull Management
Yes, you just have to use a matching post mount and rubber mount together.
It depends on the year. '92 - '93 use the two post steel version, '94 - '95 use the 3 post (somewhat misnamed as it's actually 2 studs and a bolt) aluminum Integra style mount. The same goes for the D15Z1 (VX) engine.
my 1995 vx motor originally has with the stock motor d15z1 with the 3 bolts type aluminum mount. but i sold the whole swap already a while ago.
i will use the 2 post mount bracket on the z6 with the 2 post steel version mount.
since mine came out 1995 civic vx original with a 3 point.
will the z6 2 point bracket/2 point steel mount sill bolt up without problems??? does the year matter will the steel 2 point still work????
pls let me know thanks..
fryman
12-09-2013 05:38 PM
