5 bolt turbo for ac
I am using the go-autoworks cast turbo manifold on my d16 so I am able to retain my ac. I have done my best to research what will fit and looks like the biggest ac turbo setups are 50 trims.
I need a turbo that is capable of 300-350whp. I have a y7 block with eagles/vitaras and a stock rebuilt z6 head. I am having trouble finding a 5 bolt turbo that is of good size or doesnt have an internal wg. Any pointers would be great.
what type of fuel are you planning to use? There are plenty of great turbos that come in a 5 bolt Ford-style housing that would work with that manifold.
What's your budget to spend on a turbocharger?
The more specific you are the better we can help.
you don't need e85 for 350whp, premium pump gas will do you just fine with right size injector and fuel pump, not that you can't use e85 but it just not reasonable, you will end up paying a dollar less for e85 comparing to premium but probably be filling up your fuel tank twice as fast. just my .02 cent to think about.
I'm more worried about what will fit then anything, I am putting a slim fan on the front of the condensor to save a inch or two there. Would like to keep the turbo under 800 if all possible, or at least an idea of what kind of used turbo I could look for.
The HX35 is a bit difficult to integrate into the manifold he has, due to its physical size of the cartridge and compressor housing as well as the turbine housing must modified completely. It WILL NOT allow him to have A/C.
Who is Mr Robot?
any t04b or t04e compressor housing turbo will fit (e will require slight block grinding) any t04s or ported shroud compressor housing turbos will not fit as there isn't enough clearance ...
so t3/5 bolt turbine and t04b/t04e compressor housing based turbos will all fit your current manifold
integlspwr2k
Oct 31, 2007 05:28 AM
