BLOX turbo manifold... ac compatible
Old Nov 9, 2005 | 07:19 PM
boosted k20's Avatar
Default BLOX turbo manifold... ac compatible
are the BLOX Racing TURBO manifolds AC compatible for a DC2 chassy?
Old Nov 9, 2005 | 07:45 PM
mtber's Avatar
Default Re: BLOX turbo manifold... ac compatible (boosted k20)
They are with the proper downpipe.
https://honda-tech.com/zerothread?id=1405060
Old Nov 10, 2005 | 05:29 AM
yellowturbo's Avatar
those manifolds looks really good. This design is just like the Inlinepro... just a good ceramic coating and it will look awsome !
Old Nov 10, 2005 | 07:44 AM
project dc2's Avatar
Default Re: (yellowturbo)
yeah they work well and regulate boost SOLID> its AC compatible yes with 5 bolt turbos.
Old Nov 10, 2005 | 10:38 AM
Default Re: (project dc2)
im getting a GT35R turbo. will i still be able to run this manifold and turbo setup and still keep AC? a custum 3" downpipe will be made.
Old Nov 10, 2005 | 11:03 AM
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">im getting a GT35R turbo. will i still be able to run this manifold and turbo setup and still keep AC? a custum 3" downpipe will be made. </TD></TR></TABLE>
if you get the GT35R with t3 5 bolt housing itll work.
Old Nov 10, 2005 | 06:50 PM
hey project dc2, which side will the turbo be facing? will the compressor be facing the driver or passenger side? so are there any difference in performance between the 4 and 5 bolt design? the 4 bolt design sticks out more from the turbine side than the 5 bolt?
i'll be buying the GT35R from you in about a month so i need to know. i PM'd u about the BLOX manifold. let me know where to send the payment so i can send it out to you. thanks again bro
Old Nov 10, 2005 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">hey project dc2, which side will the turbo be facing? will the compressor be facing the driver or passenger side? so are there any difference in performance between the 4 and 5 bolt design? the 4 bolt design sticks out more from the turbine side than the 5 bolt?
i'll be buying the GT35R from you in about a month so i need to know. i PM'd u about the BLOX manifold. let me know where to send the payment so i can send it out to you. thanks again bro</TD></TR></TABLE>
with a 4 bolt i dont think itll fit but a customer did on these boards with some pretty extensive block grinding i imagine. 4 bolt supposedly rumore to make a lil more power maybe but nothing proven. if its AC. compresor on passanger side.
Old Nov 10, 2005 | 07:03 PM
okay cool. i hope i wont have to do some crazy *** block grinding to get the GT35R to fit
ARMYEG
Apr 13, 2014 04:36 PM
DelSolMarine
Jan 21, 2007 12:52 PM
delsolnewkid
Apr 1, 2006 06:12 AM
Antilag
Aug 23, 2004 02:44 PM
