inboard joint won't come free from half shaft.
Old Oct 26, 2013 | 06:19 PM
B_Swapped93's Avatar
Default inboard joint won't come free from half shaft.
So I had to cut the boot on the inboard side of the driver axle due to snapping my breaker bar. plus I was in need of a new axel anyways lol my problem now Is I can't get the joint free from the half shaft (the half shaft is off the car). have tried prying with a crow bar with no success any special trick to the half shft/driver side axel getting removed.
usdm gsr trans
Old Oct 26, 2013 | 07:09 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: inboard joint won't come free from half shaft.
Had the best luck seperating these tough ones by putting a chisel between them (not maring the shaft) with a bit of tension now applied; then smack the half shaft CV with a hammer blow. This has always worked on the tough ones for me.
Old Oct 26, 2013 | 11:04 PM
grjr's Avatar
which joint are you saying that is stuck? and what is it stuck to? I'm guessing what you're trying to say is that the inner joint is stuck to the intermediate shaft?
Old Oct 27, 2013 | 04:48 PM
well I cut the axel in half so to say...lol going to take it to a shop or just get a new half shaft
Old Oct 27, 2013 | 06:00 PM
mouab18c1's Avatar
Just beat on the half shaft with a hammer. Should slide right off
Old Oct 27, 2013 | 09:12 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I always have had to remove the half shaft as well In order to separate. A lot easier when your not on your back under a car.
Old Oct 27, 2013 | 09:17 PM
i'll give it one last go i'm hitting the axel joint side. I cut the boot and left the main portion of the axel in the spindle/knuckle.
Old Oct 28, 2013 | 01:38 AM
HondaPartsHero's Avatar
Technical Hero
Ever tried one of these? You can probably rent it at Autozone or Advance
MadVladCivic
Jan 22, 2013 12:02 PM
Greatness
Jan 15, 2010 05:21 PM
Cheeech
20
Dec 22, 2005 05:55 PM
huyvu90
Sep 16, 2004 09:05 PM
GruvyTune
Jul 22, 2002 12:34 PM
