driveaxle shaft
Old Sep 16, 2004 | 08:45 PM
huyvu90's Avatar
Default driveaxle shaft
is shaft that attach to the outer cv joint bigger than the shaft attach to the inner joint?
Old Sep 16, 2004 | 08:59 PM
rev-speed's Avatar
they r both different
inner is a plunger type
the outter is tri-poid
Old Sep 16, 2004 | 09:02 PM
huyvu90's Avatar
what i'm asking is that does the shaft's diameter varies or is just the same diameter through out the shaft.
Which boot is bigger inner or outter?
Old Sep 16, 2004 | 09:05 PM
rev-speed's Avatar
my bad
i think the shaft is same diameter
the teeths count out the same
Chenzo
Sep 30, 2014 04:13 PM
B_Swapped93
Oct 28, 2013 01:38 AM
MadVladCivic
Jan 22, 2013 12:02 PM
mixmastermatt
May 13, 2007 07:43 AM
biassj
May 16, 2003 03:57 AM
