OB2 not reading, check engine light
Old Oct 22, 2013 | 12:56 PM
alex2423's Avatar
Default OB2 not reading, check engine light
Hey i got a problem with my obd2. I tried taking it to autozone but it wouldn't connect and kept saying error. Checked my fuse for my DLC in the fuse box under the steering wheel but it was good. Is it possible my OBd2 is broken or something? any help would be appreciated. Car runs fine also, I haven't noticed anything wrong with it.
Old Oct 22, 2013 | 01:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: OB2 not reading, check engine light
Year/make/model?
check the number 43 7.5A fuse under the hood
Old Oct 22, 2013 | 01:33 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Also what ecu?
Old Oct 22, 2013 | 01:42 PM
alex2423's Avatar
1997 honda del sol vtec. Checked under the hood and that fuse is good. Ecu Is a obd2a
Old Oct 22, 2013 | 05:14 PM
doctorake's Avatar
Community Builder
Is i the stock ECU? Or is it JDM?
Old Oct 22, 2013 | 05:44 PM
alex2423's Avatar
Not too sure. Could only find out that it's a p72 a02 integra gsr obd2a. Full number is 37820-p72-a02-970-101729 G1 if that helps at all.
Old Oct 22, 2013 | 06:04 PM
alex2423's Avatar
Figured it out, US ecu.
Old Oct 23, 2013 | 01:52 AM
doctorake's Avatar
Community Builder
Mods to the car? Gsr ecu , gsr engine? What harness did you use for the swap?
Old Oct 23, 2013 | 06:34 AM
alex2423's Avatar
I just bought the car not too long ago but it has b16a stock and aem cold air intake is the only mod I know of.
Old Oct 23, 2013 | 03:30 PM
alex2423's Avatar
any help would be appreciated... do i need a new ecu?
Old Oct 23, 2013 | 04:35 PM
apexi_rsx's Avatar
no there is a way to jump the ecu and get your codes . your check engine will flash. google obd1 civic code diagnosis... obd2 cars still have the jumper located by the ecu.
Old Oct 23, 2013 | 05:11 PM
doctorake's Avatar
Community Builder
You have the wrong ecu for the car also, you need a p30
Old Oct 23, 2013 | 08:23 PM
alex2423's Avatar
Not sure what u meant by jumping my ecu. Also looked up p30 ecu's and it seems there all obd1, will it cause any issues going from obd2 to obd1?
Old Oct 23, 2013 | 08:25 PM
alex2423's Avatar
also can anyone explain how this car was able to run on a gsr ecu lol.. new to hondas
Old Oct 24, 2013 | 01:49 AM
doctorake's Avatar
Community Builder
You need an OBD2A P30 ECU, they are rare but are stock for your car.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/ this tells you how to jump the service connector and see your code.
Old Oct 24, 2013 | 07:48 AM
alex2423's Avatar
alright, thanks for all your help
Old Oct 24, 2013 | 08:32 AM
XxJimmy91xX's Avatar
I had the same problem changed ecu to a stock one and worked perfect I think I have a p2t on my 99 civic
Old Oct 24, 2013 | 08:55 AM
alex2423's Avatar
I jumped it and i got back a code 92 EVAP Solenoid/Valve/Vacuum Lines
Old Oct 24, 2013 | 09:33 AM
doctorake's Avatar
Community Builder
You have a hatch and it does not have the sensor your GSR ecu is looking for. You need the OBD2A P30 ECU if you want to pass emissions. Or you can fool the ECU and it will go away but the OBD monitor will not turn on, depending on the stat this is a fail on emissions.
http://technet.ff-squad.com/code91.htm
EDIT:
nevermind, that is code 91 not 92. I suspect you may get this since you have a GSR ECU on a b16a. Get the P30 obd2a
donnieb22000
Sep 14, 2015 07:01 PM
gizmo00o
10
Mar 17, 2012 06:41 AM
LOMPSEG
Engine Management and Tuning
Apr 2, 2009 08:52 PM
chadek86
12
Jan 20, 2009 09:30 AM
inzane
Mar 18, 2002 02:11 PM
