Should I replace the thermostat when replacing the radiator?
Old Oct 22, 2013 | 11:05 AM
alpinegroove's Avatar
Default Should I replace the thermostat when replacing the radiator?
The shop suggested replacing the thermostat when replacing the radiator.
I am going to do the work myself.
Should I automatically replace the thermostat and thermoswitch as well?
Old Oct 22, 2013 | 11:12 AM
purgat0ry's Avatar
Default Re: Should I replace the thermostat when replacing the radiator?
If you feel it's suspect, sure.
Personally, I would, fluid already will be drained, hoses unplugged, may as well save some time later on and do it, I'd also replace the hoses.
But again, that's personal preference.
Old Oct 22, 2013 | 11:16 AM
Thanks. The hoses will certainly be replaced.
Old Oct 22, 2013 | 11:17 AM
I don't have a torque wrench. How necessary is that for replacing the thermostat?
Old Oct 22, 2013 | 12:08 PM
DeLSoLRo's Avatar
not too much force. think valve cover bolt. as long as its snug your good. dont go all hulk mode on it. worst case it leaks and you tighten it a bit more.
Old Oct 22, 2013 | 12:37 PM
That makes sense...
dgdarien
14
Oct 19, 2015 03:17 PM
lowRIDAH
Nov 3, 2005 08:17 AM
CTara12345
Sep 15, 2005 12:31 PM
mingbling96
May 14, 2005 06:16 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
