Clutch
Old Oct 22, 2013 | 09:41 AM
ElswickB22's Avatar
Default Clutch
Well, its time to replace my rear main seal on my civic. Its a mini me swap y7/y8 cold air engine. I am thinking that once I have the tranny off its gonna need a new clutch. (guy who sold it was sketchy about maintenance) I was researching clutch kits and specifically an exedy stage 1 kit.
Im just looking for something a little bit more durable and that will engage better. What do you guys think??
Old Oct 22, 2013 | 09:49 AM
doood's Avatar
been there done that
Default Re: Clutch
Oem exedy
Old Oct 22, 2013 | 09:58 AM
m90polk1's Avatar
Default Re: Clutch
Oem clutch if its your daily driver would make no sense to drive around with a crazy clutch setup and be stuck in traffic
Old Oct 22, 2013 | 10:44 AM
kyden's Avatar
Default Re: Clutch
exedy oem.
Old Oct 22, 2013 | 11:17 AM
purgat0ry's Avatar
Default Re: Clutch
You'll be chattering all over the town with a stage anything clutch.
Exedy OEM clutch kit will be a fantastic improvement.
It will seriously be like driving a new car if you're running on a very worn POS currently.
Old Oct 22, 2013 | 01:00 PM
ElswickB22's Avatar
Default Re: Clutch
Sounds good. Thanks guys.
Old Oct 22, 2013 | 01:46 PM
EJ Rocket's Avatar
Default Re: Clutch
While you have the trans off make sure you check the flywheel for hot spots and such also. I'm pretty sure you should have it machined when replacing the clutch but am not entirely sure since I installed a lightweight flywheel when I replaced my clutch. Good luck.
Old Oct 22, 2013 | 02:09 PM
jbpnoman's Avatar
Default Re: Clutch
Yes, when replacing the clutch, you should always have the flywheel turned.
Old Oct 22, 2013 | 05:55 PM
ElswickB22's Avatar
Default Re: Clutch
Yeah I figured that much. Gonna see how much it costs once I find a decent machine shop around my area.
MidNiteMysT
Transmission & Drivetrain
May 17, 2011 05:33 AM
moz92
Apr 4, 2011 06:56 AM
shyguy4no1
Jan 27, 2010 08:17 PM
jwhezzy2003
Aug 28, 2008 08:46 AM
cbmprelude
11
Apr 27, 2006 08:39 AM
