1995 starting/ignition problems
Old Oct 20, 2013 | 10:50 AM
rizzuto_usmc's Avatar
Default 1995 starting/ignition problems
when i bought the vehicle it came with a cool start remote and the ignition switch was disabled. the push to start remote/module crapped out so i removed it and wired the ignition back the way it was suppose to be but the vehicle will still not start. its a 1995 civic ex manual. i checked fuses and all are good. when i try to put the key into the third position it acts like its in the second position and the fuel pump comes back on. if you leave the key in the second position and use a screwdriver on the starter it fires right up. my question is do i have bad ignition switch, relay or wire? thanks.
Old Oct 21, 2013 | 12:30 AM
Solster's Avatar
Default Re: 1995 starting/ignition problems
sounds like the wire to the solenoid is still disconnected from the ignition switch or your car was an and they swapped it to 5 speed and didn't do it right.
jacobsd1904
Feb 24, 2011 01:18 PM
Elmor001
Jun 14, 2010 12:56 PM
allgo88
Apr 5, 2010 08:50 AM
carve
Sep 12, 2009 09:35 PM
Honda Virgin
Jun 2, 2004 12:34 PM
