97 del sol exterior door handle not working
Old Oct 18, 2013 | 01:23 PM
alex2423's Avatar
Default 97 del sol exterior door handle not working
Hi all,
My driver side door handle isn't working at ALL, it's as loose as it can be and just feels flimsy. I can't unlock or lock from outside or open it but I can open the door from the inside. I took the door panel off, and tinkered around a little but I don't know what I'm looking for. I don't see any wires attached to the door handle, just a metal rod that comes down but it's really loose, a spring came out pretty easily also so I'm guessing that's not good. The automatic locks aren't working for just the driver side too. Looking for help, need to know if I need a new door handle or I can fix this.
Old Oct 19, 2013 | 03:57 AM
78F350's Avatar
Default Re: 97 del sol exterior door handle not working
Both the outside and interior door handles on the Del Sols are notorious for breaking. The exterior handles cost about $10 each on Ebay and are fairly easy to replace. The interior are about $50 each at Honda parts now.
Both are pretty straightforward to replace... 2 bolts that can be reached through holes for the exterior handle. There's bound to be a good DIY if you search.
Ask more questions if you have trouble.
I'm back to add one of those DIYs that looks pretty good. For exterior, I've always just bought a new handle, but this looks like a good fix. Also it has good diagrams of the door handle removal.
exterior handle fix DIY (hondacivicforum)
doklo
Apr 6, 2021 03:54 PM
mish__
Oct 2, 2012 06:36 AM
suzieffbaby
Mar 29, 2011 04:51 PM
toben
Feb 24, 2007 08:05 PM
DelSolMarine
Aug 31, 2006 02:15 PM
