T3 Turbine Bolt Patterns
Old Oct 26, 2002 | 10:21 PM
johnisenglish's Avatar
Default T3 Turbine Bolt Patterns
I've spent the past hour searching here and on the net, but can't find anything, so forgive me with this has been covered, but...
I thought that there was only 1 style of 5 bolt patterns for T3 Turbine Housings, but I now have a .48ar Turbine Housing from a T-bird Turbocoupe, and a swing valve assembly off of ebay, and the Housing is about a centimeter shorter then the swing valve assembly? wtf?
Old Oct 28, 2002 | 11:53 AM
Carlito Brigante's Avatar
Default Re: T3 Turbine Bolt Patterns (johnisenglish)
there is a 4 bolt and 5 bolt. the thunderbird uses the 5bolt so any bigger kit you will use for the turbo the downpipe wont fit.
cheapturbo.com has the 5 bolt flange so you can go external. you just weld the flapper shut and make a custom dp utilizing that flange.
hope that helps
Project99EK
Aug 24, 2006 10:58 PM
D-Man
Sep 12, 2004 06:49 PM
austrian type-R
Sep 19, 2003 08:58 AM
H22coupe
Nov 20, 2002 01:59 PM
