A.c help b20b swap
im about to replace my compressor but im expacting the worse
ive been told its my iacv but my idle is solid when the a/c is off. so ill clean my iacv while im there
witch compressor should i get i was told the crv compressor over charges my condensor or w/e and its causing my idle to fall i was told my compressors bad....
i was even told Try going with a higher amp alternator that might help with the shaking
my problem is as soon as i press the a/c button my car feels like its about to stall if i barley press the gas idle will fall on its face
if it still messes up, i'll just wait tell taxes and get a whole new a/c system condenser , compressor and lines for my swap because this is ridiculous ....
I had the same problem. I went to a A/C service station they drain the whole system out checked for leaks and recharge the Freon to specs and now is all better. The system had moisture. Check the A/C belt make sure is tight correctly. What ECU are you using.?
Rooftop-Special
Sep 2, 2010 08:08 PM
tronic
Feb 9, 2010 07:58 AM
duyfash0
Sep 16, 2009 08:05 PM
